Home > Puma (Tdci) > Thank you |
land 0068 japan Member Since: 27 Jun 2024 Location: kanagawa Posts: 10 |
Thank you
27th Jun 2024 9:00am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7939 |
can you define warm? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Jun 2024 11:55am |
Thank you
28th Jun 2024 2:32am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1913 |
Try the CHT sensor had issues similar myself and found the cylinder head temperature sensor was faulty.
The give away for me was the temp needle moved slightly when cold, it’s a cheap part so worth a try 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
28th Jun 2024 7:39am |
ok, so its around correct running temp then.
Sounds like a faulty sensor giving over read and sending it into a restricted/limp. VCV is worth a change for the funds involved too. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Jun 2024 9:33am |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 754 |
I would swap out the SCV and see if that makes a difference. Relatively cheap albeit a bit of a to change.
Have you had any codes read yet? Jim |
28th Jun 2024 10:40am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17276 |
What do you mean by this? Which valve? |
28th Jun 2024 10:57am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
... that also came to my mind, when cleaning the "fuel valve" VCV it might be toast now.
28th Jun 2024 4:29pm |
Thank you
13th Jul 2024 5:00am |
Thank you
13th Jul 2024 5:02am |
i had very similar issues with my TDV6 Discovery a few years ago and this ended up being the MAF sensor, to save a few quid as i expect you have spent a small fortune already try to borrow of a mates?
mine happened towing a caravan and just as i got on the M50 which meant a very long trip home at 30mph 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
13th Jul 2024 6:33am |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 454 |
Sounds like a right nightmare..
I'd be trying to look at live data from as many of the sensors as a tool will accommodate.. When cold and when in fault Strange there are no codes.. Are you using a generic obd tool or manufacture specific..? That might show a bit more.. |
13th Jul 2024 9:23am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2400 |
what diagnostic tool are you using for calibrations and any DTCs?
And unlikely the PCM is causing trouble. Puma 110" SW ............................................................. Earth first. Other planets later |
13th Jul 2024 2:40pm |
Thank you
14th Jul 2024 4:57am |
