![]() | Home > Puma (Tdci) > Flexible part between DPF and exhaust pipe cut/change |
cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 50 ![]() ![]() |
Never have removed the dpf the gearbox slides back over the exhaust and you have room to change clutch if you want to remove gearbox unbolt the end case and remove output shaft and flywheel and gearbox can be removed
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Thank you, for your informtion.
I have already done this, but had issues in the past with a transferbox oil leak. So was looking to fit both units connected as a whole. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2188 ![]() ![]() |
Iv just had the clutch replaced by Engine 710 in Edinburgh. They take both boxes completely out as one complete unit. The photos show the DPF stayed in position but with the first exhaust section cut and clamped. Cross member was simply removed by its 4 bolts for easy removal of boxes. Both props off. This is the easiest, quickest and less fiddly way of doing the clutch in their opinion but still a 7-8 hr job costing £1k. ![]() Click image to enlarge ![]() Click image to enlarge |
