![]() | Home > General & Technical (L663) > ACC with g4 problem -SOLVED |
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 99 ![]() ![]() |
Have you updated the firmware of your gap tool?
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 60 ![]() ![]() |
hope that yes, i have 3 days after buying and downloading from gap...
any trick like with parking asist (2x reboot and close) or have did you do it your ways? |
do you mean throught iid tool updater?
solved!
my mistake, I stood on the brake while uploading the new settings, that's why the engine always started... now I tried without the brake and everything was as it should be - the error disappeared after 15 minutes! Thank you P.S. Park assist how is here anywhere does it work? |
defending Member Since: 07 Jul 2024 Location: Edinburgh Posts: 5 ![]() ![]() |
Are you using G4 pro for this ?
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 156 ![]() ![]() |
There is no difference in functionality between the Pro and the Individual user IIDTool. The only difference in use is that the individual user IIDTool only performs the advanced programming functions on the vehicle it has been activated on (diagnostics are VIN lock free!) or where VIN licenses have been purchased. The Pro will work on any LR we cover with all functions.
@defending: I hope this answers your question - it does not matter if it was a Pro or a regular IIDTool BT ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
Would this work for XS edition 250d MY24 ?
I have a 2023 P400 XS and have activated ACC with no problem.
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
yes ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
