Home > Puma (Tdci) > immobiliser problem
Page 2 of 2 <12
laundry_man
United Kingdom 2010 Defender 90 Puma 2.4 HT Santorini Black
First I like to thank all those who have responded to my post.
Well The landrover is now starting as it should do.
I received my new Nancom and connected it and looked at the various screens, but did not reset anything. But after disconnecting the Nancom I tried to start the Landrover, and it did start, so I have not found the problem which caused it to fail starting. I hope this is not going to be an intermittent problem.
The nancom gave the following fault codes, which I have cleared, I don't know how long the codes have been stored and probably due to a failing 12 volt battery some years ago.
So I assume its now carry on and hope the fault does not come back.
Thanks
Derek.............>
FAULT 1 OF 4
ECU: Instrument Pack
CODE:U0100
Lost communication with engine control module/powertrain control module 'A'
(HISTORIC)
BUS SIGNAL/MESSAGE FAILURE -
MISSING A MESSAGE.
FAULT 2 OF 4
CODE:P1602
Immobilizer/engine control module communication error
(INTERMITTENT)
FREQUENCY MODULATION/PULSE WIDTH MODULATION FAILURE -
NO SIGNAL.
FAULT 3 OF 4
ECU: Engine Management
CODE:P068A
Engine control module/powertrain control module - power relay de-energized too early
(INTERMITTENT)
GENERAL FAILURE INFORMATION -
NO SUBTYPE INFORMATION.
FAULT 4 OF 4
CODE:U0155
Lost communication with instrument cluster control module
(INTERMITTENT)
NO SUBTYPE INFORMATION. 2004 Freelander TD4 Sport
2010 Defender 90 Hartop
Post #1038811 30th Jun 2024 9:02pm
Page 2 of 2 <12
