![]() | Home > Technical > Can't engage gears (R380) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
If gears can be selected when engine off and not when on, that indicates to me that the clutch is not disengaging between engine and box.
anotherrick Member Since: 02 Feb 2024 Location: Lancashire Posts: 33 ![]() ![]() ![]() |
What could be the cause as everything is practically new
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
fitted the clutch plate the wrong way round? I did it to a Td5 I was building lol
Not Impossible but they say not. Did offer to check though.
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Have you adjusted the clutch pedal Instagram @defender_ventures
Empire Tuning - Agent |
Yeh was one of the first things tried
Give Luke at LOF a call. Explain the situation to him and ask his advice.
He is a really really nice bloke that will have time for you. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 639 ![]() ![]() ![]() |
Engage first, then start the engine with clutch depressed, try pulling away. If it works as it should, but won’t select gears when running, usually caused by new clutch plate on worn flywheel, more common now with all Tdi’s getting old and worn out, the new clutch plate drags on high spots or ridges on the flywheel surface so the gearbox internals are still turning when the clutch is depressed. Clutch plate will bed in and gears will select again.
Regardless of the fault the garage should be able to figure the fault out however majority of garages now are clueless in the operation of a vehicle without being able to plug in diagnostic scanner to tell them what sensor to change, Land Rover specialists included |
Spoken to him, he's a nice guy and very helpful. He said its unlikely clutch is in backwards as it'd be very difficult to do that on a tdi, he also said it could be out by 60 degrees which can cause issues. |
This seems very likely given the vehicles age/mileage. I'll be passing all the info onto the garage today. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
What does this baffling statement mean? |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1144 ![]() ![]() ![]() |
So hang on I don't really understand the problem. You used reputable parts and a shop and the shop is telling you that after them assembling it it does not work.
Sooo, 'shop', what are you going to do about it? Take it apart again I assume and fix it. So what is the problem, they took it apart and could not find an issue? What are they proposing? |
I assume the mounting of the pressure plate assembly? You would think dowels and bolt holes would prevent that. |
How would that make the slightest difference?
