Home > Technical > Can't engage gears (R380) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5726 |
If gears can be selected when engine off and not when on, that indicates to me that the clutch is not disengaging between engine and box.
29th Jun 2024 7:51pm |
anotherrick Member Since: 02 Feb 2024 Location: Lancashire Posts: 30 |
What could be the cause as everything is practically new
29th Jun 2024 8:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
fitted the clutch plate the wrong way round? I did it to a Td5 I was building lol
30th Jun 2024 6:40am |
Not Impossible but they say not. Did offer to check though.
30th Jun 2024 8:02pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2173 |
Have you adjusted the clutch pedal Instagram @defender_ventures
Empire Tuning - Agent |
1st Jul 2024 10:25am |
Yeh was one of the first things tried
1st Jul 2024 2:48pm |
Give Luke at LOF a call. Explain the situation to him and ask his advice.
He is a really really nice bloke that will have time for you. |
1st Jul 2024 2:55pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 625 |
Engage first, then start the engine with clutch depressed, try pulling away. If it works as it should, but won’t select gears when running, usually caused by new clutch plate on worn flywheel, more common now with all Tdi’s getting old and worn out, the new clutch plate drags on high spots or ridges on the flywheel surface so the gearbox internals are still turning when the clutch is depressed. Clutch plate will bed in and gears will select again.
Regardless of the fault the garage should be able to figure the fault out however majority of garages now are clueless in the operation of a vehicle without being able to plug in diagnostic scanner to tell them what sensor to change, Land Rover specialists included |
2nd Jul 2024 2:49am |
Spoken to him, he's a nice guy and very helpful. He said its unlikely clutch is in backwards as it'd be very difficult to do that on a tdi, he also said it could be out by 60 degrees which can cause issues. |
2nd Jul 2024 9:33am |
This seems very likely given the vehicles age/mileage. I'll be passing all the info onto the garage today. |
2nd Jul 2024 9:34am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
What does this baffling statement mean? |
2nd Jul 2024 10:38am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1084 |
So hang on I don't really understand the problem. You used reputable parts and a shop and the shop is telling you that after them assembling it it does not work.
Sooo, 'shop', what are you going to do about it? Take it apart again I assume and fix it. So what is the problem, they took it apart and could not find an issue? What are they proposing? |
2nd Jul 2024 11:56am |
I assume the mounting of the pressure plate assembly? You would think dowels and bolt holes would prevent that. |
2nd Jul 2024 11:58am |
How would that make the slightest difference?
2nd Jul 2024 3:48pm |
