Home > Technical > Help please - difflock problem! |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
jack up both wheels and see first mate
30th Nov 2011 7:44pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
With 1 wheel off the groung and gearbox in neutral you should be able to turn the wheel around.
If you still had it in gear 15 degr is OK. My 90 Td5 does more I think. You will hear cluncks. What do you expect to see with 2 front wheels off the ground? Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
30th Nov 2011 8:06pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
I'd stop messing with jacks, get it on some grass or gravel and reverse up and down in a straight line. if the same, go full lock to full lock in reverse for a few minutes (say or 5 times per side)
30th Nov 2011 8:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8035 |
15deg is about right when the diff lock is engaged with one wheel off the ground.
Have you looked underneath to see if the lever is moved all the way over when disengaged? a front diff seizing is not something i have come across, they normally just break the centre of the crown wheel. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Nov 2011 8:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17391 |
Ok, been out and tried some more things.
Both front wheels in the air, spin one and the other turns in the same direction if cdl unlocked. Lock CDL front wheels both lock (back wheels are on the ground). CDL is working fine. The only things that could cause this are 1) I have a front difflock I don't know about or 2) the front diff has seized. It's an 07 so probably 2 pinion. Any suggestions for best place for new 4 pinion diff? Assuming crownwheel & pinion are ok, would an airlocker be cheaper than a new diff? |
30th Nov 2011 9:52pm |
pin has collapsed in the front diff. Cheers
1st Dec 2011 6:43am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
there is a second hand 4 pin diff on ebay at the moment out of a RR states on advert it will fit a defender but im sure someone on here will know for sure DEFENDER 90 TDCI XS,
1st Dec 2011 7:34am |
Since I need the vehicle back in action ASAP, I have ordered a replacement diff from Ashcroft Transmissions.
I have ordered up newly built unit with heavy duty crownwheel and pinion set and torque biasing differential (so a much better unit, and built by professionals who know what they are doing and care!) and, even including the refundable surcharge on the old unit and delivery this is around £400 cheaper than a new 4-pin diff assembly from Landrover! It is being built for me now and has been promised for Monday. What a pleasure to find such a polite, helpful and customer-focussed firm! |
1st Dec 2011 12:37pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
nice one, get one for the rear aswell! |
1st Dec 2011 1:08pm |
how many miles have you done ,what sort work has it done ,seem soon for a new diff
bad luck mate. |
1st Dec 2011 1:44pm |
It's an 07 plate DC with approx 80k miles on, County spec so no ABS or TC. It does a fair bit of off-road work inc. with trailers but even so it's a disappointing failure. However I was always intending to fit lockers of some kind at some time (though not this close to Christmas!) so all in all I am not too fed up. Those lovely folk at Ashcroft's have made me happy again!
Will now have to decide whether to fit an ATB or air-locker in the rear - any recommendations? |
1st Dec 2011 5:03pm |
with no TC i'd go for an ashcrofts locker, they make there own and you'll need a compressor so you could have onboard air...good for pumping tyres and possibly air tools |
1st Dec 2011 5:07pm |
blackwolf let me know which one you get and how it goes,i too im thimking of fitting lockers but not sure which to go for so any info would be good thanks
1st Dec 2011 6:37pm |
in my opinion if you are doing something that requires lockers (racing aside) then get a true air locker that you dictate when you need it. The ashcroft locker is very good, with better engagement than the ARB too. Cheers
1st Dec 2011 7:36pm |
