Home > Puma (Tdci) > Puma Defender Wading Kits
Page 1 of 3 123>
TJ101
Has anyone else heard that 07 model Defenders do not require wading kits California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1034 8th Jan 2008 6:19pm
AndrewS
Shocked Why is that then Question because they're never out of the dealers. Or they break down when 'water' is mentioned. Or they throw a diff when you mention the word FORD
Post #1035 8th Jan 2008 6:25pm
TJ101
Was speaking to mantec earlier today, ordering some bits, including a wading kit,, they have been told new 07 Defenders do not require wading kits, and that it has been confirmed by Land Rover Rolling Eyes
so you tell me,,
Andrew, have you fitted some breathers ?? Question California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1036 8th Jan 2008 6:32pm
AndrewS
TJ101 wrote:
so you tell me,,
No I have not. There are breather pipes fitted to the axles the same as a TD5 Defender so I presume from your info they must be better quality on the New Defender.......The only thing that is Rolling Eyes
Post #1037 8th Jan 2008 6:48pm
TJ101
A mail from Mantec, when i asked the question Question
Quote:
Yes, we thought so too, we do not have any written confirmation from Land Rover. However, we manufacture the items for Land Rover (ie/ their accessory range & G4 Challenge) and the wading kit is one item that we has been confirmed that is not required for the 07’s.
Post #1038 8th Jan 2008 6:55pm
JSG
Hmmm, interesting.
Post #1039 8th Jan 2008 11:08pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
I kind of think if your going into water above 2 ft then a wading kit might be useful full stop, regardless of what LR say.
Why would the new Defenfer be any different to the Td5? The gearbox is in a different position (further back as is the rear axle) but the axles are the same hight and roughty in the same position and both need a breather - dont they?
Or are we just talking about the engine? If so why did I see a 90 Hard top in a dealer showroom with a snorkle on it?
Russell.
Post #1040 8th Jan 2008 11:24pm
TJ101
Russell.
Hi,, bodyshells are all the same,bar slight mod to the bulkhead, axle,s in the same place as Td5 , 300tdi etc etc, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1041 8th Jan 2008 11:32pm
Japseroony
Ok, so why do the new TDCi's not need wading kits?
Post #1043 8th Jan 2008 11:38pm
JSG
From reading comments on various forums I guess the reason could be improved breathers fitted as standard and properly waterproofed electronics.
I wouldn't think that they are saying you don't need a snorkel though.
Post #1044 9th Jan 2008 9:19am
AndrewS
The Red Dwarf will be up on the hoist today I will have a look and report back. I also have a TD5 defender in the workshop so I will compare the two.
Post #1046 9th Jan 2008 9:32am
AndrewS
OK so I have compared the new 07my axle breathers with the TD5......They are identical apart from the colour of the cable ties that hold the pipes to the vehicle. The TD5 has white/clear ones the 07MY has black ones.
Maybe they are not making 07my wading kits because the TD5 one will fit Question
Post #1054 10th Jan 2008 7:15pm
TJ101
Thanks Andrew,, save me a job Whistle
mmm, , could be they told Mantec, not to make any, because they were going to source elsewhere, but then Landrover do not list a wading kit in the acc cat for 07
Best now dig out you pic's re fitting the snorkel,,, a job for the weekend Rolling Eyes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1055 10th Jan 2008 7:26pm
Japseroony
So if the breathers are the same as the Td5, then they still need a wading kit which presumably will be the same as the Td5, but I understand the engine air intake is completely different to the Td5.
Chaps at Cheviot 4x4 have been trying to fit a Safari Snorkel for me and the airbox and piping etc is completely different - I know LR offer a Mantec snorkel but these in my opinion are not as good as the safari type especially if you are going to chip/re-map the engine etc so maybe the chaps that make the safari ones could get onto the case and offer some piping etc?
Any suggestions?
Russell.
Post #1068 14th Jan 2008 2:15pm
AndrewS
Thumbs Up
Any suggestions?
Russell.
The existing Safari RAI is not designed if fit the 07 Defender. Just wondering why the Mantec is not as good as the Safari when it comes to tuning Question
Post #1071 14th Jan 2008 2:45pm
Page 1 of 3 123>
