Home > Puma (Tdci) > Puma Defender Wading Kits
Page 2 of 3 <123>
TJ101
Japseroony wrote:
So if the breathers are the same as the Td5, then they still need a wading kit .
Not according to Landrover, they don't
Japseroony wrote:
Chaps at Cheviot 4x4 have been trying to fit a Safari Snorkel for me and the airbox and piping etc is completely different - I know LR offer a Mantec snorkel but these in my opinion are not as good as the safari type especially if you are going to chip/re-map the engine etc so maybe the chaps that make the safari ones could get onto the case and offer some piping etc?
Russell.
Would be interested to hear you thoughts as to why not,,
now having fitted a Safari to a TD5, and a Mantec to a 07,, recently, the Mantec would be my first choice Smile California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1080 14th Jan 2008 5:55pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Sorry I am not sure how to use the quote thing on here so you will have to read all of this to see if I reply to your post Smile
1 There is nothing wrong with the Mantec snorkel but the air flow is not as good as the Safari ones. Any snorkel will restrict the airflow and anyone with some knowledge about airflow will understand that if you require air to flow oneway and then make it do an about turn by 180 degrees you are restricting the flow even further - adding a snorkel to any vehicle is like asking you or I to breath through a 4 ft pipe, you can breath, but it takes effort!!!
2 Landrover say that the Defenders dont need breathing kits on the Td5 or the new ones due to the fact that the "safe" wading depth on a defender is the top of the wheel rim - not the tyre but the rim and the basic kits are good enough for that - if however you wish to use the defender as it was supposed to be used you need a wading kit.
I agree that with regards to the breathers, the positioning and height on the Td5 and new TDCi are un-altered other than the of the colour of the cable ties.
3 I agree the Safari snorkel wont fit, but if you give up at the first hurdle then you should not be driving a defender. Anything can be made to fit and Cheviot 4x4 have found a way for me Very Happy
Russell.
Post #1090 15th Jan 2008 10:42am
AndrewS
Says Who Question
Russell.
I know they can be fitted as I was at my dealers J V Lyke when they fitted a Safari RAI to an 07 Defender. When I saw what was needed I decided to fit the £150 cheaper easier Mantec RAI.
As far as giving up and not driving a Defender WTF Shocked I don't think so Crying or Very sad Go back to a horse and cart, then you wont need a RAI Whistle Razz So when Safari copy the Mantec RAI would you still insist that they supply the option that wont fit so you can have a 'challenge' in trying to get it to fit a car it was not designed to. BTW how much did Cheviot 4x4 charge you for fitting the Safari RAI Razz Thumbs Up
Post #1091 15th Jan 2008 5:21pm
Japseroony
Andrew,
Why are you having a go at me with all of this "WTF" stuff on your post? I have not said anyting against you or Mantec other than the Safari RAI is a better system - the reason for this has been explained in my previous post!!!!!
If you choose to fit the cheaper inferior option then so be it.
I know the Safari RAI is not designed to fit the 90 Defender but that does not mean it wont and as its a "better system" then with a small amount of inginuity it will fit - oh and yes I am sure Safari will make the piping for one soon but your dealer has done this anyway!!!!!
When I mentioned giving up and not driving a Defender this was a reference to the fact that when owning a Defender, if you fall at the first hurdle you and give up then maybe a Defender (or any LR come to that) may not be for you, but this was not directed at you as it was a general comment, so get off your high horse FCS Mad
With regards to the cost, you will never know Very Happy
Post #1094 15th Jan 2008 7:27pm
AndrewS
Japseroony wrote:
Andrew,
I'm hot having a go at you did you not notice the Razz in my post.
Why is it better you have not explained why. Or where are you getting your info from.
Have you actually seen an 'approved' by LR Mantec RAI Question Oh does the Safari still come with painted mild steel brackets Question The Mantec one has Stainless Steel Whistle
Japseroony wrote:
I know the Safari RAI is not designed to fit the 70 Defender but that does not mean it wont and as its a better system then with a small amount of inginuity it will fit - oh and yes I am sure Safari will make the piping for one soon but your dealer has done this anyway!!!!!
Again says who Question
I own 5 Defenders 1 Disco 3 and a CJ7 Jeep so I simply drive over the hurdles. You were answering my post so I would presume it was directed at me. I don't care for horses so you wont catch me on one. Shocked
Ring Ring Ring Ring Hello is that Cheviot 4x4 Question Hello I have an 07 Defender can you give me a price to fit a Safari Snorkel Question Yes the one thats not designed to fit the 07my Whistle Whistle Laughing Laughing
Please don't be offended its just a bit of banter Thumbs Up It does not matter who's RAI anyone fits. If we all did the same thing and copied each other just think how boring life would be. Thumbs Up Thumbs Up
One thing I have noticed though, after fitting the RAI to the 110sw performance has improved. I did not notice it on the Utility as we bolted loads of extras to it the same day.
Post #1104 16th Jan 2008 7:21pm
Japseroony
Well thank goodness for that as being built like a brick s***house (not) I was gonna have to come down and sort you out good and proper young man Laughing Laughing
So, as I still aint managed to get the hang of the quote thing, here I go with an attempt to reply. The Safari RAI is a more direct airflow system and allows a greater amount of air to the engine. This is only a problem if you are either going to chip or re-map the engine for greater power as it would then need a greater amount of air. Indeed, a chap that I know of had to fit 2 Mantec RAI onto his Td5 as he replaced the intercooler, chipped the enging and various other things but the engine was starved of air with only 1 RAI.
Prior to fitting the second RAI he did try the Safari RAI (albeit not fitted properly) but did not like the looks of it (strange chap) and found it was ok etc.
I am not saying the Mantec is not a good system and indeed they have improved the looks greatly, actually it now looks like the Safari RAI Very Happy Very Happy but the Safari is better for the above reason - its all about airflow.
So why have you got all of those Defenders? Do you own an offroad driving school?
My dog dont much care for horses either as he was kicked in the head once - think thats why he is now so stupid Rolling Eyes but me, I aint bothered either way, but they do make a good sandwich.
Have you had any work done to the engines on your Defenders or are they standard? Thinking of having mine re-mapped by Allisport but not sure if its worth it with the new engine as the power is much better.
Post #1109 17th Jan 2008 6:53pm
TJ101
Sorry Russel,, but, if the Mantec is good enough for Landrover,, then that's good enough for me
I have binned 2 Safari RAI now, One on the Hybrid, as it was always getting hit, as they stick out to much, replace with a Southdown, much better for the job its get used for !!(and still goes very well, so no flow problem their !) The second one on the old TD5, for much the same reason, and replace with a Mantec,(anyone wants a good (as New) Safari RAI Rolling Eyes )
OK, working on your theory,,re air flow,, why then is the bore on the 07 Defender Mantec RAI, the same as the one RAI on my Sport,, Question and that has a proper engine,(nearly twice the size) not a taxi lump !! Rolling with laughter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1110 17th Jan 2008 7:28pm
Japseroony
Good enought for LR Rolling with laughter you must be joking, what about the door seals, turbo's blowing, gearboxes/diffs blowing, water leaks, lack of underseal/rust proofing, badly fitting doors/panels etc etc etc as they are all good enough for LR eh Thumbs Up
As previously stated I am not saying there is anything wrong with the Mantec RAI but once you start re-mapping the engine the airflow is restricted at times - that is all I am saying.
The bore on the RAI is not the issue, more the way the RAI is asking the air to flow Exclamation Exclamation
Post #1127 18th Jan 2008 10:41am
TJ101
Question then, Which required the more air,,, a 4.4 V8 or a chipped 2.4 diesel, Question
Mine are fine
Japseroony wrote:
turbo's blowing,
No,
Work fine thanks
Japseroony wrote:
water leaks,
No, not a drop, even with all the water we haveing down here this week , but will admit its the first Defender i have had that doesn't Whistle
Only time will tell
No, mine fit ok Smile
Bar from the ABS sensor lead,, mines been fine,, Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1128 18th Jan 2008 11:22am
Happyoldgit
TJ101 wrote:
<huge>
So has mine Tim (famous last words probably).
Post #1132 18th Jan 2008 7:03pm
JSG
Mine's booked back in to the dealers for Monday week.........
for it's 12k service.
Post #1140 19th Jan 2008 11:58pm
Happyoldgit
Blimey - mine's still only on just over 3000 mls (other vehicles in the fleet too don't ya know)
Post #1172 25th Jan 2008 9:32am
JSG
Its going in early - I've not done 12,000 miles in it yet.....
just 11,650 Rolling with laughter I do seem to rack up the miles - but that includes a few camping trips, trips to Cornwall and a holiday in France last summer.
Post #1178 25th Jan 2008 3:37pm
dullbird
Australia 2007 Defender 110 Puma 2.4 SW Tonga Green
the td5 safari snorkle can be fitted to the new 07 defender as someone has done it here in sydney.......
he had to take the guard off for some cutting and trimming on in the inside but it can be done..... YOU KNOW REHAB IS FOR QUITTERS!!!!
Post #1305 7th Feb 2008 8:25am
El Cyd
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all
is there any update regarding wading kits for the tdci additionally how well hardened/protected is the ECU.
Regards If it aint broke its just waiting.
Post #4013 24th Sep 2008 12:31am
Page 2 of 3 <123>
