Home > General & Technical (L663) > Apple Maps in the gauge cluster - anyone worked it out?!
dizeeduckie
I'm loving having Apple Maps in the gauge cluster, but what it actually displays seems to be hit-and-miss.
Sometimes it shows my position and, at the bottom, the road I'm on.
Sometimes it shows my position and, at the bottom, the road I'm on and my time of arrival.
And sometimes it shows my entire route - a zoomed out map so I can see my start point, end point and a line showing the route between them. But it never zooms in.
Does anyone know if there's a setting to decide what is shown? Or is it just pot luck?
Post #1034683 14th May 2024 9:04am
Huwrhys
I find it displays the opposite to the main display. Ie it shows direction up on the drivers display then it shows the whole map north up and vice versa. It doesn’t show on the HUD at all. 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1034701 14th May 2024 10:28am
dizeeduckie
Mine mirrors - shows the same on both.
I can't work out how to change what is displayed on either.
Post #1034702 14th May 2024 10:30am
Huwrhys
I had the new security update recall carried out on Friday morning and when I got back in it said there was a new update to 4.1.4.
The update deals with speaker routing on 24MY and some PHEV stuff.
Also phantom engine warning light issues. 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1034703 14th May 2024 10:42am
dizeeduckie
That's... interesting.
Post #1034709 14th May 2024 10:59am
Huwrhys
I meant to add it had not made any difference to my map issue. 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1034710 14th May 2024 11:01am
Defender22
Have the same issue completely random what it displays. Glad it’s not just me going mad.
Post #1037902 20th Jun 2024 3:51am
haymeister
Japan
When navigation is set then Apple Maps in the gauge cluster shows opposite to what is on the Pivi Pro screen.
If in Pivi Pro, Apple Maps is zoomed out showing the entire route, and North locked, then in the gauge cluster it will show you zoomed in, with the orientation locked in the direction of travel.
You can change this by pressing the North arrow icon on the top left of Apple Maps in Pivi Pro.
Picture attached.
 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1038005 21st Jun 2024 8:49am
