![]() | Home > Td5 > Cylinder head bolts .... torque sequence and lubrication |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
ok head on, bolts in finger tight ... and just notived that the AMC head bolts have a different torquing sequence that LR/Haynes 30nm,65nm,back off 90 deg,65nm,90deg,90deg,90deg,45 deg Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
A.Rubio Member Since: 04 Mar 2017 Location: Rocafort -Valencia Posts: 32 ![]() ![]() |
I advise you to follow AMC's instructions, but more importantly, blow out the holes in the engine block well so that there is no oil left inside them because the tightening would be incorrect.
Hi,
OK AMC - Yeah thats what i thought Re presence of oil. I've used a syringe and some tubing to suck out as much oil as i can and then used an old head bolt to repeatedly. screw it in hand tight ;remove and clean oil off threads untll no appreciable oil visible. Did this with the head off so was actually screwing the bolt in further than it would do when the head was on. It's as good as i can get. Head now back on and ill repeat the procvess 1 more time A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
