Home > Technical > Defender 90 rear shock absorbers
Tractorman
Scotland 2011 Defender 90 Puma 2.4 HT Indus Silver
I have a 2011 Defender 90 which has done 64k miles. One of the rear shock absorbers needs replaced (the top cover that encases the piston arm has broken away and arm is exposed). I plan to replace both rears - any thoughts on the attached photo of Britparts "basic version" or should I go upmarket? My Landy has an easy life with no off-roading.
Also what is correct torque setting for upper & lower nuts?
Thanks.
Post #1037681 17th Jun 2024 12:39pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
LR genuine ones are very good quality and last well. Any aftermarket ones will have varying degrees of damping in comparison to the original ones so may feel somewhat different.
Post #1037682 17th Jun 2024 1:02pm
shaynecm
I would stick with OEM and avoid aftermarket shocks.
There is BILSTEIN ones if money no object and you want something with more curb appeal.
Post #1037683 17th Jun 2024 1:10pm
Genuine, they last. $W33T $0U7H3RN $UG4R
Post #1037694 17th Jun 2024 4:29pm
MK
LR044347
This is the P/N for a 90". Make sure it is genuine as some vendors list other non genuine with this number or some equivalent bit. Puma 110" SW
Post #1037696 17th Jun 2024 4:44pm
Mdm
any decent brand but not cheap ones and defo not Britpart ones
Post #1037702 17th Jun 2024 5:45pm
Tractorman
Thanks Guys for great feedback - so much appreciated. So definitely not cheap ones! Any thoughts on torque level for nuts or maybe just tighten up hard? My hobby is working on old classic tractors (collection of 8 much to my wife's displeasure!) - often no torque settings - just use common sense!
Post #1037705 17th Jun 2024 6:23pm
MK
Not torque info, but pay attention the way all the washers and bushings go. Puma 110" SW
Post #1037706 17th Jun 2024 6:32pm
Zed
For shocks I use the torque setting of tight but not effing tight. WARNING.
Post #1037707 17th Jun 2024 6:57pm
landy andy
Certainly not tight on the bottom fixings. You just need the rubber bushes just starting to be compressed not squashed flat
Post #1037710 17th Jun 2024 7:45pm
piechipsandpeas
Torque values for shock absorbers from the WSM. Upper fixing 85Nm, lower fixing 28Nm.
Post #1037726 18th Jun 2024 12:12am
Chicken Drumstick
This would be nonsense.
Post #1037729 18th Jun 2024 2:45am
Chicken Drumstick
Re: Defender 90 rear shock absorbers
Thanks.
Standard are ok and a good all round mix. But there are better shocks out there. For a budget offering the Britpart Cellular Dynamic is a good shock. It is a twin tube design and will be a major upgrade if you ever tow or haul anything.
If you off road consider a +2” shock as you’ll get more suspension flex. But you may need to add dislocation cones or longer springs.
Post #1037730 18th Jun 2024 2:48am
Mo Murphy
I'll concur with Mr Drumstick that the Britpart Cellular Dynamic shock is a good competent shock and is extremely good value for money. Ive had them on my 90 now for the last 5 years and they have served well with long motorway runs to southern Europe, green laning and commuting. They are not, however, reassuringly expensive and lack the bragging rights of the more expensive brands. Sorry.
50 Shades of Pennine Grey
Post #1037731 18th Jun 2024 3:25am
Naks
Bilteins FTW, or if you can afford them, Fox Thumbs Up --
Post #1037737 18th Jun 2024 6:57am
