![]() | Home > Tdi > 200TDi speedo lights |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I replaced mine with Green Led Bulbs and held them in place with a bit of bluetack. Many many miles later still going strong! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter ![]() |
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 52 ![]() ![]() ![]() |
Good idea
Worth a go. 2010 90 LHD soft top 2010 110 XS 1985 90 soft top |
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 65 ![]() ![]() |
I superglued the black bits to the back of the dash and put up with white light
Blue Blood Member Since: 14 Jun 2022 Location: Shropshire Posts: 131 ![]() ![]() ![]() |
I broke the black bits off being careful not to get any parts in the housing and put rubber grommets in the holes. Then I used after market green LEDs which when pushed in fit very snug so won't be coming out any time soon and will hopfully still keep dirt and dust out, they don't get overly warm, eat less energy to run and should last a good while.
I would say the only potential downside is just how bright they are if you are out in the middle of nowhere with no street lights (it pretty much illuminates the cab green, but does look quite cool). |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5244 ![]() ![]() |
my dad has the same issue, Speeding cables i think its called. might be able to fix it. But you can buy replacement units for these. My dad has decided to tell the company who is rebuilding his to fit a new speedo.
![]() ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
