Home > In Car Electronics > Grey plug under cubby |
From closest to the gear levers:
C3692 - Sensor-Temperature-Exhaust gas-2 - Pre catalytic converter temperature sensor C3691 - Sensor-Temperature-Exhaust gas-1 - Post DPF exhaust gas temperature sensor C3693 - Sensor-Temperature-Exhaust gas-3 - Post catalytic converter temperature sensor although sensor 2 &3 may be wrong as orientation of diagram is uncertain. |
13th Feb 2016 3:04pm |
How you getting on with this? By chance, I found this old post, which seems to suggest that it may not be plug and play: http://www.defender2.net/forum/topic21305.html?highlight=alpine |
18th Feb 2016 12:14pm |
JDH Member Since: 20 May 2015 Location: Horsham Posts: 61 |
Hi Supacat, sadly have been busy with work to chase it up too much, land rover have no idea what plugs into it or what plug I'm even talking about and i can't seem to find a sub with a plug like that anywhere on the internet! like i said last time i really don't understand how they have no idea what it is, it must have been fitted in the factory unless the fairys put it there...
19th Feb 2016 6:40pm |
HossBog Member Since: 22 Jul 2015 Location: Glos Posts: 131 |
Click image to enlarge I've got one as well, just in front of the cubby... Seems to point 'forwards' towards if you know what I mean... 2002MY Defender 90 H/T |
21st Feb 2016 10:59pm |
Hi BossHogg
Yours is a different plug all together! that is a diagnostics plug on a td5 |
22nd Feb 2016 9:25am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6595 |
Correct, diagnostic plug. You can tell by the trapezoid shape. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
22nd Feb 2016 11:47am |
Super, at least I know what my plug is for now.. 2002MY Defender 90 H/T
24th Feb 2016 11:45am |
xrodney Member Since: 09 Jun 2024 Location: Malta Posts: 8 |
cannot see original images.
I had a look and did not see the gromet and wires. should I have a look below that metal plate? |
13th Jun 2024 11:53am |
