![]() | Home > Puma (Tdci) > 110 rear mud flap fixing |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 ![]() ![]() ![]() |
Belt and braces option: fit a Gwynne Lewis Mud Flap kit
- Stepped tub https://gwynlewis4x4.co.uk/product/defende...ub-gl1003/ - Square tub https://gwynlewis4x4.co.uk/product/defende...ub-gl1008/ Quick fix - bolt back on with repair washers Slightly less pikey fix - fit a length of aluminium angle along the bottom of the panel and refit flap > 110 XS Double Cab |
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 90 ![]() ![]() ![]() |
Same thing happened to mine.
https://yrmit.co.uk/product/mudflap-wing-s...ender-110/ |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1036 ![]() ![]() ![]() |
I just used a length of aluminium left over from some old secondary glazing. Much cheaper.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3790 ![]() ![]() |
Length of ally and a few rivnut bolts
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 ![]() ![]() ![]() |
It's a very common problem, more a matter of "when" than "if".
![]() I bonded a length of aluminium angle with Sikaflex to reinforce the inside bottom angle of the of the wing and have had no trouble with then since. IN fact the repair was sufficiently strong to mean that some time later when I reversed over one mudflap on rough terrain the mudflap (rubber) pulled off the bracket, damaging neither, and could simply be reattached. The bracket stayed firmly attached. |
I have fitted a length of alu. My only thoughts being...
If the flap was to catch on something then the bracket bolt pulls out and the flap hangs. No major issue. However if we reinforce the section then the weak link is removed. If the flap was to catch now could it pull the whole tub/wing side in with it? > 110 XS Double Cab |
As noted in my second para above, when I reversed over my reinforced mudflap and ripped it off, it just popped the rubber off the rivets which had attached the rubber to the bracket, and did no damage to the bracket or the rubber, nor to the wing.
Chugaboom Member Since: 02 Mar 2022 Location: Sussex Posts: 31 ![]() ![]() ![]() |
That’s brilliant all, thank you. I knew you’d all have some great advice and options.
Thank you |
shaynecm Member Since: 10 May 2024 Location: Norwich Posts: 63 ![]() ![]() |
YRM do a replacement part for the Wing.
https://yrmit.co.uk/product/mudflap-wing-s...ender-110/ Gwen lewis kit is awsome but i still fitted YRMs re-enforcement as its ali and gwens is Galv Steel. but have the rest of the mud flap kit. |
cjasmith97 Member Since: 02 Jun 2024 Location: South Tyneside Posts: 4 ![]() ![]() ![]() |
Mine was exactly the same - glad I saw this post!
