Home > General & Technical (L663) > Warped brake discs
lightning
Warped brake discs
Looks like l have warped brake discs as there is a vibration and feel through the brake pedal when l brake from higher speeds.
ls this likely to be a warranty item at 18 months/13,000 miles or is it down to me? l used to get this with my Alfa Romeo and l would fit new ones and they'd warp again.
Eventually l took the discs and got them skimmed, and they would never warp again.
But the local machine shop has gone. Has anyone else had brake discs warped, and is it usually the front discs?
l've actually got a spare pair of new "take off" front discs.
Post #1037221 12th Jun 2024 1:36pm
J77
Disco 3/4 owners had this issue, I think some got them replaced under warranty. 24MY 90 D250 HSE, Tasman Blue
Post #1037228 12th Jun 2024 3:44pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Not the same vehicle but on a Jeep I used to own the discs would crack every time, probably due to too much heat build up from dragging the brakes too much when towing, I then changed to brembo ones and never had a problem again. I think they would last about 25k, or two sets of pads. I always used dot 5.1 as the boiling point is higher, but modern stuff probably has that anyway.
Post #1037232 12th Jun 2024 4:12pm
When DOT4 is concerned which is recommended the specs can vary quite a lot.
I went for Castrol React DOT4 premium, Brembo comes close I believe in specs.
Many others have a much lower boiling point and some out there are quite rubbish to be honest.
Defenders are heavy, even more so when towing, and brake fluid as mentioned is hydroscopic so takes on water over time so around 2 years is a good interval to change it.
Max water content is around 4% IIRC, which you can test, but realistically you don’t want to go above 3% really.
Last time I tested mine it was about 2.5% and is around 2 years old, so hence due a change now.
You get be best braking performance under 2% moisture content, the nearer zero the better. $W33T $0U7H3RN $UG4R
Post #1037233 12th Jun 2024 4:31pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
No issues on my Disco 4’s.
Disco 5 and 110 D250 Hard Top I owned at same time, ironically both had the vibration at higher speed braking at similar times, and slowly got worse, can’t remember mileage but Disco 5 had more miles on than the HT,.
The dealer did high light it with JLR but they were not playing, they just said wear and tear.
The dealer did give some good will despite JLR being their usual customer focused selves. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #1037246 12th Jun 2024 7:23pm
lightning
l did some braking tests from higher speeds and it doesn't seem that bad now. l will fit my spare discs if it gets any worse, and get the originals skimmed.
Post #1037257 12th Jun 2024 9:31pm
RDR
I had all my disco 5 discs and pads replaced at first service due to vibration. Initial response was jog on from JLR. I raised a complaint as the car only had 7k miles on it and they agreed to cover as a good will gesture. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D5 MY19 HSE - Now Sold
D4 MY16 HSE Luxury - Now Sold
D4 MY12 HSE - Gone
D3 MY06 S - Gone but not forgotten
Post #1037265 13th Jun 2024 5:25am
Retroanaconda
It’s a common fault on the smaller brake size as fitted to base models. At that mileage you’ll get nowhere with LR.
Best option is to replace the parts.
Post #1037268 13th Jun 2024 6:08am
LandyMax
My 2020 D240 110 had to have them replaced after 10 months and 22,000 miles and they'd already been skimmed. We tried to get them replaced under warranty as we'd heard it was a known issue but got nowhere. Hopefully the bigger brakes on my D300 will last longer.
Post #1037331 13th Jun 2024 4:07pm
sasa
Czech Republic
I had the same problem, D200, 1 year, about 30 Tkm.
Sometimes it rains, other times it seems quite ok. As part of the warranty, they do not take...
I don't believe in the original, when I change I will buy another brand
Post #1037443 14th Jun 2024 12:38pm
Defender22
Will drop you a pm!
Post #1037900 20th Jun 2024 2:42am
abyss
Australia
Anyone knows the aftermarket brake pad and discs can be used? Brembo makes them?
Post #1037918 20th Jun 2024 8:19am
sasa
Czech Republic
yes, i thik so. I was looking at them, i am going to give them instead of genuine, but till now i did not realize it...
Post #1037921 20th Jun 2024 8:53am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I had my front disks and pads changed under warranty at around 9500 miles and a year old
Here's the original thread
https://www.defender2.net/forum/topic85204.html? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1037942 20th Jun 2024 10:58am
ben2012
I’m on my third set of front discs and pads (the original plus 2x replacements), first set at circa 4k miles then again at circa 11k miles, first set under warranty no issues with claim, second set were a battle with LR and dealer got the swap based on the 12mths warranty on the replacement discs. Very poor though and clearly not upto the job. Mines a D250 110
Post #1037981 20th Jun 2024 10:13pm
