Home > My Defender > My Baby
Page 5 of 5 <12345
dgardel
Italy
doriano71 wrote:
very nice Thumbs Up
Ciao Doriano ben arrivato in Defender2.net
Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #88418 10th Sep 2011 12:58pm
pathfinder
1989 Defender 110 200 Tdi USW Rimini Red
added a bit of stainless to clean things up!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  One wife Livid!
Post #92877 5th Oct 2011 9:48pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Liking the stainless steel door trims, where from may I ask.
I also recognise that climb in the Lake district, managed that with a bit of wheel spin as well, a couple of failures in the group I was with so pleased to make it with no damage, it's a lot more of a step than it looks in the picture mind!. Took my 200tdi fitted 90 up there this year (not quite as clean looking as yours but a good runner none the less.
DJ
Post #103284 29th Nov 2011 12:33pm
mymini007
1986 Defender 90 200 Tdi HT Java Black
This is one of the best looking Defenders I have seen, If mine looks a quarter as good as this when its finished I will be happy.
Bow down
Post #103337 29th Nov 2011 4:45pm
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Just stunning. Red looks billiant on it. And the quality of the workmanship looks top class.
Well done Thumbs Up
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #103371 29th Nov 2011 7:14pm
Romadog
Looking good.
Where did you get your rocksliders? Did you coat them or is that how you recieved them?
Also where did you get those shiny sill trims ?
Post #103386 29th Nov 2011 8:10pm
pathfinder
OK to answer a couple of questions. The stainless steel sill covers I had made up by an engineer friend of mine and simply placed some Defender decals on them.
The rocksliders I bought and after experimenting with various non slip coatings that was not up to the job I had them sandblasted and treating in Linex, which is used in the back of pick up trucks etc and is very very tough and long lasting, it is baked on and is that tough that it is used to coat military weapon discharge chambers! so will take a bullet at close range Shocked
Since my last posting I have made some more subtle upgrades.
I have installed some overhead map pockets, in the 2nd row passenger area and in front where the now obsolete sun visors
once was, I have gone a bit mad with LED lighting and it has transformed the vehicle dramatically, for very little cost, I have illuminated the underbonnet too that is triggered by a plunger switch that activates when the bonnet is opened, I also fitted gas struts to hold the bonnet and installed thermal fire retardant soundproofing too.
I installed a marine consumer unit in the rear that is linked directly to the second battery, I fitted a red led to the input power of it which acts as a visual indication of the power state, the 2nd row LED courtesy lights are wired to activate when the doors are opened.
I have custom made some Carling switch legends too, and pictured is the pilkington heated windscreen being fitted.
Post #103682 30th Nov 2011 8:59pm
mymini007
Just seen your picture on the cover of the 2012 LROI Calender
Nice work ! You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #103708 30th Nov 2011 10:10pm
d j hutton
thanks for the tip on the door threshold trims, good idea with adding the decal, got some of that 'etched glass look ' vinyl somewhere. Seen some plain ss ones elsewhere on the net so might give those a try.
Other additions all look good, busy man Very Happy
Nice pic on the calendar, been on that track as well this summer.
DJ
Post #103747 1st Dec 2011 9:25am
pathfinder
just fitted a Wolf snow cover, toyed with idea for last couple of years but couldn't commit, mainly because I could not justify the price for what seems a simple item, anyway got one in passivated zinc plate and had it powder coated and fitted it adding rubber edging trim to neaten it up and close a gap at the side!
The amount of air the blower fan produces as not been effected, as some people said it restricted air flow, but I have an Eberspacher heater and heated windscreen too so I don't depend on the standard heater system anyway, incidentally the Eberspacher is superb and highly recommended, I have a thermostat with it and I have turned it to minimum and leave it on all the time, it keeps an ambient temperature and the landy simply doesn't freeze up! it also illuminates that horrible dampness and mildew forming during winter and keeps a comfortable temperature always!
I am looking for a TD5 dash binnacle (not clocks) just the housing and warning light cluster, so if anyone has one spare that they want to sell drop me a line?
Post #108182 18th Dec 2011 2:15pm
Buzz
2010 Defender 110 Puma 2.4 DCPU Tonga Green
Looking great as always!
Post #108226 18th Dec 2011 6:48pm
Morea
Hello, could you tell me which wheels and tires? thanks http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #251952 17th Jul 2013 6:24pm
Mikemillar89
Hi, what split charge system did you put in this, and awesome truck btw!
Cheers mike
Post #251973 17th Jul 2013 7:30pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Haven't seen any posts from pathfinder in a while.. Confused is he still around? Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #252103 18th Jul 2013 9:44am
Page 5 of 5 <12345
