Home > Puma (Tdci) > Help Late Puma Owners - Turbocharger Actuator. |
I recently replaced the actuator on my 2013 2.2 to solve a problem with sticking vanes. Yon can read all about it here, in case it helps:
https://www.defender2.net/forum/post853115.html#853115 I can tell you that the correct actuator should be stamped G-72: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Oct 2020 8:05pm |
Darth Payne Member Since: 03 Nov 2019 Location: Sussex Posts: 6 |
Thanks Darren
One other question, could you possibly confirm the part number on the compressor housing? My original had the number JKM2, the replacement JKM1. I wondering if the location of the mounting for the actuator is different to clear the aircon compressor? |
14th Oct 2020 8:10pm |
No, I'm afraid not. I didn't remove the shield to expose it, I'm afraid.
Scratch that - I've just realised that the number you're talking about is just visible in my picture of the bare actuator. It's not a brilliant angle to be honest, but it looks to be JKM1: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 14th Oct 2020 9:01pm. Edited 1 time in total |
14th Oct 2020 8:29pm |
That angles good enough!
Really appreciate it sir! |
14th Oct 2020 8:42pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2755 |
l wonder if he managed to fix his Puma.
17th Nov 2023 5:35pm |
I did.
Turns out the exhaust housing is specific to the late Puma; dealer / supplier struggled. I had the existing turbo rebuilt. |
17th Nov 2023 5:43pm |
Owen_91 Member Since: 11 Jun 2024 Location: Southampton Posts: 1 |
Related to turbo actuator part numbers, I am fairly sure I need to replace the actuator on my 2010 2.4tdci.
Symptoms: limp mode when I drive over 60mph for about 5mins or more, reset by cycling the ignition. No engine lights nor error codes. I can move the turbo vanes with the actuator disconnected and it moves freely (hot and cold). Checked the wiring and all seems to be okay. When I start and rev the engine, the actuator does not move the vanes at all. The part numbers on the actuator currently fitted are 752406, 009206, and G-48. But I'm seeing a lot of G-34 actuators online and I'm not sure what the difference is. The Defender is on 160k miles so the turbo may not be original. Any thoughts on what the G number refers to, and which is required? I am wondering whether the current actuator is right which could be the root cause. |
11th Jun 2024 7:40am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20342 |
Make sure the pivots on the EA actuator bar are kept periodically lubed with light oil from a dripper.
Don’t grease them unless it’s the LR dedicated ceramic grease which costs a fortune! 3 in 1 light oil sorted mine out, it’s been good ever since but they do get sticky, that I turn affects the actuation of the EA and operation of the tube vanes, will also induce a small amount of lag too. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Jun 2024 9:35am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Gents
can anyone tell the position of the turbo actuator lever/link (up or down) BOTH at idle and with the engine off? I am chasing a smoke problem on a 2.4 model. Thx Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
24th Jun 2024 3:57pm |
I hope I am lucky this time and I get a word of advice.
Should the turbo vanes moves aboslutely freely? After I removed the "circlip" from the actuator lever I found out the internals were stuck and I could not move the lever whatsoever. After I few taps into he lever it was free. However, I still feel a bit of friction by moving up and down the lever. Puma 110" SW ............................................................. Earth first. Other planets later |
22nd Jul 2024 7:26pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1780 |
Very free and smooth!
23rd Jul 2024 5:29pm |
As above, basically no resistance at all on all of its travel. $W33T $0U7H3RN $UG4R
23rd Jul 2024 5:45pm |
Thx. Looks like some soot built up mine. Puma 110" SW
24th Jul 2024 12:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17369 |
I found that the best way to describe it is to say it should feel as though the linkage has broken and isn't actually doing anything in the turbo. It is surprising how freely it moves if it is working correctly. |
24th Jul 2024 12:26pm |
