Home > In Car Electronics > Head unit fed from leisure battery
falkster
Germany 1988 Defender 110 V8 Petrol CSW Trident Green
Hi All,
As I have a battery cut off switch, I am considering to connect the radio in the car to the leisre battery, so that I don't lose the time display and stored radio stations every morning...
Is it as simple as connecting the cable that would go to the ignition and connect it to my leisure battery instead?
Thanks,
Falk
Post #1037062 10th Jun 2024 11:13pm
landy andy
You don’t have to go to ignition if it is required for memory as that is a permanent live, not a switch live. That way the radio would still come on/off with key but retain it’s memory
Post #1037074 11th Jun 2024 7:07am
Mo Murphy
You could bridge the cut out contacts with a small piece of wire and a fuse big enough to supply the radio but will blow if there is any further electrical draw.
50 Shades of Pennine Grey
Post #1037076 11th Jun 2024 7:38am
TexasRover
Normally a radio has a permanent live for the power consumption (amplifier) and to maintain any memory and a switched live just so that it knows if it should switch off when you switch off your engine etc. The switched live normally does not use a lot of power.
So if you wanted to keep the radio going at all times unless you physically switch it off you combine the two wires onto a permanent feed.
If you want to have a regular radio setup but power it from from the leisure battery to avoid drawing down the main battery you probably best off connecting the permanent live wire to the leisure battery, but leave the switch live to the contact, but then you have to leave your keys in the contact to listen so maybe you should also change over the switched wire to the leisure battery. It's all common ground so it should work just fine.
Modern radio's use very little power though so I am not sure you are gaining much.
Post #1037079 11th Jun 2024 7:53am
Power it completely either from one battery or the other, do not use both. If you use both you run a significant risk of destroying the radio if you attempt to start the vehicle or switch anything high current on while the isolator is off.
Post #1037159 11th Jun 2024 6:34pm
landy andy
My head unit in my motorhome and many others is powered by their leisure batteries and switch live via the ignition. No problem for the ten years I’ve had that, and not read any issues from others. Some are wired like that a standard as they are used for tv sound as well.
Post #1037174 11th Jun 2024 7:44pm
You’d need to ensure both supplies have common ground along with the head unit.
The ignition is the red switch and the yellow is battery power.
If you put both together you’ll flatten the battery rapidly if you forgot to turn it off.
The yellow will draw approx 5mA - 40mA on standby and whilst saving its memory.
(Which is normal). somewhere between 6 to 14A when in use.
The ignition probably only up to 200mA when on, none when off.
If you put this on constant live it will still flatten the battery, just a bit slower than with the unit on.
Standby current on yellow is up-to about 40mA is normal.
Red should be off, unless the ignition is on and the Alt is providing charging voltage and current. KEEP CALM AND Drill ON
Post #1037177 11th Jun 2024 8:10pm
Fair enough then, personally I wouldn't do it but if it hasn't fried your radio yet it must be OK. Thumbs Up
Post #1037182 11th Jun 2024 8:28pm
falkster
The memory is usually the yellow wire out the head unit, right? So i could potentially bypass the cut-off switch with just that cable and keep everything radio related to the starter battery? This would actually be my preference as the leisure battery is further to the back of the vehicle...
Post #1037188 11th Jun 2024 9:43pm
falkster
Thanks everyone. al ot of food for thought as always. Thumbs Up
Post #1037189 11th Jun 2024 9:44pm
falkster
cut off on earth rather than battery live?
Need to bring this up again...
I now realised that my battery cut-off is on earth...
That completely throws me as I simply don't know how I could get the memory in the radio to work. Basically the radio shows midnight every time I turn the cut-off switch.
do I need to run a wire from my battery (starter or leisure?) earth to the radio's earth, basically bridging the cut-off switch?
But by doing so, would I not create the earth connection for the whole electrical system that the cut-off switch cuts off??
I am seriously confused.
Post #1038254 24th Jun 2024 9:17am
jst
just do what Mo Suggests and easy simple fix to your problem. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1038257 24th Jun 2024 9:41am
Mo Murphy
4" of wire, fuse and fuse holder, just like I said 2 weeks ago 🤔, doesn't matter that it's on the earth.
Post #1038259 24th Jun 2024 10:04am
falkster
empty as originally quoted on wrong response...
Looks like I can't delete a post(?).
Post #1038260 24th Jun 2024 10:38am
falkster
Mo
sorry not great with electrics. Wasn't aware that this works with earth as well... It wasn't my intention to make it look as if I dismissed your input.
how much would you think is big enough a fuse?
Post #1038261 24th Jun 2024 10:40am
