![]() | Home > In Car Electronics > OEM Alpine Subwoofer Wiring |
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 ![]() ![]() |
its p21. 10 amp
Ed |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 226 ![]() ![]() ![]() |
Hi Martin, Can you still supply this lead, and let me know how much it is, Thanks Ashbyandy |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Yes, on site shop: https://defender2.net/shop/defender-alpine...-p120.html
xrodney Member Since: 09 Jun 2024 Location: Malta Posts: 13 ![]() ![]() ![]() |
Can you supply only the top part? |
Drop me a PM
Done
Crash7 Member Since: 21 Feb 2024 Location: South Posts: 36 ![]() ![]() |
Farmerben, are you able to provide more information on the fix you mention above? As opposed to start a new thread I have revived this as there is a heap of good info. I have an MY14 90 Hardtop that had the factory wiring under the cubby, I installed the factory LR Alpine amp and connected, I also connected the cable behind the headunit, 2 x RCA and a grey plug into the existing harness. The 10amp fuse is present but the sub does not operate. However, I am running a non-stardard headunit, Stinger Heigh 10, which may be part of the problem? - The RCA are connected to the sub-out RCA's and the Sub is switched on in the Stinger menu, but the sub does not operate. Any input appreciated ![]() |
leonvh, did you solve this issue in regards to the sub not working with a new headunit? Are you able to share any information? - Thanks |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
I’m not sure what the LR system is, but normally you’ll have a left and right rca for stereo, then fused live and ground and a 12v rmt.
The 12v rmt is fused or should be fused 300mA fast blow fuse is ideal just behind the head unit in-line on blue white, it turns on the amp where the head unit has an audio output. Some Amps don’t need it as they signal since the RCA input but the most reliable is the Rmt12v method. I’d imagine LR used the 12v remote method within their loom, if it’s not connected then you’ll have no audio and the Amp won’t come of. Unless there is a blown fuse, which can be blown accidentally but if it’s in-tact then it’s not that. If you do find you need to connect the blue white stripe rmt12v, then do fuse it near the head unit because if you don’t you could fry your HU or worse. If there is any connectors ensure they are clean, and fully connected home and not loose or partially connected. ![]() ⛽️🛢️⚙️🧰💪 |
Andyslandytd5 Member Since: 06 Nov 2021 Location: Southampton Posts: 52 ![]() ![]() ![]() |
Hi Crash, I have the factory Sub woofer and am thinking of going for the Stinger head unit. Did you get yours working in the end? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
Give me a little longer, I have been talking to Mud, whom I bought my Heigh10 from, they have been fantastic, I have what I am told is a solution..,
You need to provide an ignition feed from the Heigh10 to power the amp. Connect the P-Control wire on the Heigh10 to the BLUE wire on the factory sub wiring under the cubby box. I have not tried this yet, but am planning to at some point! |
Okay great will wait to see how you get on
![]() 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
How do you go from under the cubby to the battery compartment without drilling any holes in the seatbox? Thanks
