Home > Puma (Tdci) > Puma earth straps
Bluest
Puma earth straps
Is their list of the main earth locations on a Puma anywhere? Are they obvious if I crawl underneath? I’m having some occasional no start problems. 2007 110 TDCi Station Wagon XS
Post #1036860 8th Jun 2024 6:04pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Clean up the earth that connects to the transfer box, even if it looks ok clean it up Smile
Post #1036862 8th Jun 2024 6:35pm
Zed
This earth does seem to cause a few issues. Is there an improved connector or method available? WARNING.
Post #1036871 8th Jun 2024 8:21pm
Basically it’s exposed to extreme conditions, extreme vibration, moisture, temperature changes and the most likely culprit is during any transmission work such as a clutch change it gets whipped off, and then screwed back on in a rush often at the end of a job.
It can then be dirty, not tightened up enough and things like that. Probably considering it’s quite a big job to change the clutch fatigue sets in and sometimes it just gets nipped up the nut on the thread or even left hand tight as I unfortunately experienced once.
And that can cause the most strange issues such as indicate left, right indicator comes on.
Hazard lights flash the entire dash lights, all due to the poor earth distribution via multiple circuits and voltage leakage.
It’s a quite resilient design really, it’s just when it gets worked on and all electrical connections can degrade over time, especially those in harsh conditions. $W33T $0U7H3RN $UG4R
Post #1036873 8th Jun 2024 8:42pm
andy63
Re: Puma earth straps
No list as such but from doing a few jobs I've noticed these..
The battery main earth cable has a bolted connection to the transfare box.. That same cable has a another spliced connection that has a bolted (I think) connection to the main chassis box section..
On the opposite (drivers side) I have a couple of earth connections on to the side of the transfare box..
And finally at the rear of the drivers side front wheel arch I have an earth strap from body work to chassis..
There is also a multiple earthing point on the bulkhead in the engine compartment which should be easily spotted..
That's all that come to mind.. But I'm sure there will be many more points around the vehicle for lights etc..
Post #1036881 9th Jun 2024 6:21am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Here‘s an abstract diagram of all earth points https://www.defender2.net/forum/topic70711.html
Post #1036885 9th Jun 2024 7:25am
Millerdark
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Fuji White
Can you describe the starting problem in more detail. How do you eventually start it, when it does not start?
Post #1036959 9th Jun 2024 5:23pm
Bluest
After the car has been sat a while, a few days or weeks, not exactly sure, the problem occurs. Turn the key and nothing happens other than a click. This might repeat 2 or 3 times then it bursts into like as normal.
Alway kept on a CTek, I always let the glow plug light go out. Issue doesn't seem to occur if it's been used recently. 2007 110 TDCi Station Wagon XS
Post #1036966 9th Jun 2024 6:20pm
