Home > In Car Electronics > Puma radio
B blaney
Northern Ireland
Puma radio
Genuine puma radio won’t turn on but if I press the eject button screen lights up with “eject” then turns off again.any help much appreciated
Post #1036574 5th Jun 2024 1:58pm
Ianh
What year Puma have you ? There are two fuses you need to check, but they are in different locations for the 2.4 and 2.2.
Post #1036578 5th Jun 2024 2:44pm
It’s possible the connector to the rear is loose, or if there is a fuse in the rear of the unit that could be loose or the LR factory fuse box fuse. Is it aLR Genuine one or aftermarket? KEEP CALM AND Drill ON
Post #1036589 5th Jun 2024 4:52pm
B blaney
Northern Ireland
Genuine one
Post #1036645 6th Jun 2024 8:26am
B blaney
Northern Ireland
2010
Post #1036646 6th Jun 2024 8:29am
Martin
Site Admin
Probably missing the "aux" (key pos 1) supply which is a white/orange wire from fuse 44 (on a 2.4).
Is your heater blower fan working and your cig lighter/12V socket?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1036652 6th Jun 2024 9:35am
