![]() | Home > In Car Electronics > Puma radio |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2149 ![]() ![]() |
What year Puma have you ? There are two fuses you need to check, but they are in different locations for the 2.4 and 2.2.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
It’s possible the connector to the rear is loose, or if there is a fuse in the rear of the unit that could be loose or the LR factory fuse box fuse. Is it aLR Genuine one or aftermarket? TheThunder Rolls🇬🇧🇺🇸
B blaney Member Since: 05 Jun 2024 Location: Cushendall Posts: 3 ![]() ![]() |
Genuine one
2010 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
Probably missing the "aux" (key pos 1) supply which is a white/orange wire from fuse 44 (on a 2.4).
Is your heater blower fan working and your cig lighter/12V socket? ![]() ![]() |
