Home > Puma (Tdci) > Should the engine be holding revs between gears?
Page 1 of 3 123>
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
As the title suggests really.
Occasionally - or it may just be I only occasionally notice it - but when I'm changing between the gears the engine tends to hold the revs momentarily.
So for example, lets say I'm in 4th and approaching traffic lights or a round-about, I'll depress the clutch and coast until I know whether I'm going down the gears or continuing to accelerate and move up a gear (perhaps a poor example but hopefully you get what I mean). When this happens I notice the revs will hold for a few seconds and then begin to fall.
I assumed this was to allow rev match during gear changes - helping with a smoother transition - but thought it was worth asking as I saw another post relating to revving issues....
Post #554298 7th Aug 2016 7:16pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Yes it is normal,
I'm sure someone more knowledgeable will be along shortly to explain why
Failing that, some "helpful" person will just point you to the search function! Very Happy
Post #554310 7th Aug 2016 7:46pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Iggle is correct, mine does it, it is normal, I believe it is an anti stall feature, I also believe it is called Rev Hang.
A search should give you a few results. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #554315 7th Aug 2016 7:52pm
K.M
I assumed it would be normal as there are benefits to it doing it but I thought it was certainly worth checking... especially seen as she is already at the Dealership having something else fixed!
I know that the Nissan 350 / 370Z have a feature whereby the revs are held between the gears to allow for a smoother transition.. therefore by the transit of properties... we drive a Nissan sportscar!
Post #554321 7th Aug 2016 7:58pm
Happyoldgit
Yes perfectly normal, the idea behind it being to reduce drive line shock loading [ie clunking as the slack is taken up amongst the various components]. Many people these are not used to changing gear smoothly in what is, after all, a fairly sloppy transmission as they have grown accustomed to slick changes in modern car gearboxes. Steve.
http://forums.lr4x4.com
Post #554337 7th Aug 2016 8:26pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
I must admit it confused be a bit when we picked up the wifes new 2.2 this March.
I assumed it was to help keep the turbo spooled up which virtually stops spinning in my TD5 when you take the foot off the throttle Sad
What I dont like in the 6 speed box is the POP in and out of the gears, whereas the old R380s smoothly go from gear to gear.
I also find the gear lever position confusing hopping from from the daily TD5 to swambos TDCi its never where your left hand expects to find it or the direction you expect it to go in!
Add into the mix the spare car, an old D1 and all three are completly different.
I do like the 2.2's Anti stall, it feels much more confident than the TD5 though He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #554410 8th Aug 2016 8:38am
Yes, I get it rarely too and mine is a 2.4 as well.
I think it occurs when you make a gear change a little quicker than you should ideally do so.
Of course, if you've been driving a 6sp Def for a few years your pretty experienced hence the rare occourance of it occurring.
Usually is 2nd 3rd and 4th as you say.
I would worry, completely normal - as normal as a Defender could be. Rolling with laughter
Post #554418 8th Aug 2016 9:19am
Eau02467
If it's a 2.4 and you are getting rev hang it isn't normal, it is caused by a failing clutch pressure switch. More than likely your clutch fluid has never been replaced and is full of moisture.
Post #555118 10th Aug 2016 6:57pm
BrickBox
I have changed my clutch switch and I am still getting the annoying Rev hang on my 2.4
I have bridged it to try that and also no luck.
Any other tips? Is it worth changing the master cylinder? 2008 2.4 110 Utility Station Wagon XS.
Post #1036405 3rd Jun 2024 6:17pm
I know it sounds daft, but check your brake light bulbs - I seem to recall that a failed brake light can, bizarrely, cause this on the 2.4!
Post #1036409 3rd Jun 2024 6:53pm
BrickBox
I will definitely check that!
Weirdly I’ve only just changed my rear tail/brake lights! 2008 2.4 110 Utility Station Wagon XS.
Post #1036412 3rd Jun 2024 7:09pm
BrickBox
Shocked Confused I’ve just been out to check and I do not have brake lights!
Side lights, indicators and reverse lights all working, apart from brake lights… 2008 2.4 110 Utility Station Wagon XS.
Post #1036415 3rd Jun 2024 7:48pm
Interesting, sort out the brake lights and hopefully the rev hang problem will be cured.
The delights of recent Land-Rovers!
Post #1036417 3rd Jun 2024 8:08pm
BrickBox
Electrical side isn’t my strong point - can you point me in the direction of the brake light fuse as a starting point to check, please? 2008 2.4 110 Utility Station Wagon XS.
Post #1036421 3rd Jun 2024 8:26pm
BrickBox
After a search it looks like I need to check F13 fuse for the rear lights? 2008 2.4 110 Utility Station Wagon XS.
Post #1036468 4th Jun 2024 12:46pm
Page 1 of 3 123>
