Home > Puma (Tdci) > Help please, I have a haunted accelerator pedal! |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 775 |
Hi Zed
I'll just put this out as a possibility, but could it be that your battery is on its way out and your VCV is also on its last legs??? I'm sure that folk will be along with other possibilities.. Jim |
2nd Jun 2024 11:25am |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3278 |
Thanks for the reply Jim. VCV was changed 8 months ago, a Denso from Pete Bell. It could be a problem but the symptoms are very different from when the last one died.
Battery is a good shout as it’s a few years old but I haven’t had any issues with it and voltage seems ok. The alternator did cross my mind though. WARNING. This post may contain sarcasm. |
2nd Jun 2024 11:51am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1997 |
Perhaps an Intermittent earth issue, one that serves the throttle pedal ? There is a common Earth point on the bulkhead in the engine bay that’s worth checking, cleaning contacts etc.
2nd Jun 2024 12:16pm |
Thanks Ian. That’s exactly the type of thing I was thinking of, loose connection, wire rubbed through etc. Whereabouts is that earth point? WARNING.
2nd Jun 2024 12:22pm |
This topic provides good info on the earth locations in engine bay, behind dash etc with pictures. https://www.defender2.net/forum/topic48404.html
Worth checking the wiring diagrams to see which earth point could potentially be the culprit. Ps, when the battery light comes up on the dash, are all the other dash gages still working ok ? If not it could be ignition switch or battery terminal clamps need loosening, tapping down and re tightening. |
2nd Jun 2024 12:58pm |
Thanks that’s very helpful, exactly what I need.
Yes it was only the battery light. All the others went out as usual with just the battery light showing for about 30 seconds, maybe a minute while voltage showed zero on gauge. Then it went off and gauge showed normal. WARNING. This post may contain sarcasm. |
2nd Jun 2024 1:23pm |
If it was not for the battery light staying on for a while on the IPAC I would think it’s the throttle pedal sensor(s), the wiring to the throttle pedal, or the connector.
Have you read any DTC’s ? Worth removing the connector to see any moisture or corrosion and giving it a clean. Check the loom, especially where it goes through the bulkhead, and test the throttle pedal sensors. There are a few topics on here re fault finding on the throttle pedal. |
2nd Jun 2024 8:23pm |
Thanks. No codes thrown up, because that would be too easy!
I’ll have a search on here to see how to test throttle and sensors. WARNING. This post may contain sarcasm. |
2nd Jun 2024 9:13pm |
Right, I’ve checked all the earth points I can find plus every part of the loom that I think may rub and all seems well. I’m thinking it may be an idea to change the alternato. It’s the original part and one of the only things not replaced under my bonnet!
Does anybody have a recommendation or know the original manufacturer? WARNING. This post may contain sarcasm. |
6th Jun 2024 2:53pm |
I spotted this in an old topic. So it does seem the battery light staying on during initial start, and potentially the throttle issue , is an intermittent charging issue.
Have you tested the voltage across the battery (with a multimeter ) when you initially start and the red battery light is on ? It should be circa 14 volts. If circa 12 volts or less that will indicate a charging issue. If a charging issue then checking cable and connections from the alternator would be next, and if they are ok then that leaves the alternator. Re the alternator, I think a genuine new Bosch one seems to be the cheapest quality replacement. A useful read https://www.defender2.net/forum/topic48237...alternator Especially Blackwolf’s post.
6th Jun 2024 4:21pm |
Thanks Ian, that will be next on my to do list. These intermittent issues are so frustrating but I’ll get there in the end! WARNING.
6th Jun 2024 4:38pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20339 |
Failed clutch switch or on its way out, or OBD device interfering with the ECM.
Which motor shindig be seeing at least 13.8v minimum. 14.1 to 14.8v is the sweet spot of a good current producing alternator and the voltage should be relatively stable at idle without loads going on or off. Power surges are normally I found clutch switch related, limo mode turbo actuator sticky. All sorts of things can happen if main primary power is loose or disturbed such as a loose ground, or battery clamp. Might be worth noting all DTC’s and clearing them, disconnect battery after for 15 mins then reconnect after. Usually these things are intermittent but not really serious or that costly, most of the time anyway. The VCV causes poor performance, low mpg but more notably lack of top end power especially in 6th. A little rough idle worse in cold weather but when it’s in its death throes will just cut out the engine, and then get just worse and do that more often just cuts out the engine. Defiantly try disconnecting ECM related OBD devices though, they can cause problems. If you’ve had to pedal to the floor, that’s limp mode, when I’ve had that once before it wad the turbo actuator stuck open that reset by itself once home, but after lubing the pivots it never came back and the DTC told me it was turbo actuator related. Just suggestions at least, good luck. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 6th Jun 2024 7:18pm. Edited 1 time in total |
Cheers Steve, I’ll definitely try disconnecting the battery. My initial thought was also the OBD gauge as they are infamous for causing trouble, also a piggy backed fuse I was running an extra USB on, but the issue returned anyway. VCV is good but a new clutch switch I ordered arrived today so that will be next on the list along with checking alternator connections. Next week I’m finally dealing with my leaky slave cylinder so I will be able to check all those hard to reach electrical points while fitting a new clutch and assorted gubbins. WARNING.
6th Jun 2024 7:16pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Battery light on cluster is controlled over CAN from the ECU.
The ECU monitors the alternator charging status. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
6th Jun 2024 8:09pm |
