![]() | Home > Puma (Tdci) > 1100/1200 RPM power hesitation |
WestCountryPete Member Since: 30 Sep 2023 Location: Wiltshire Posts: 42 ![]() ![]() ![]() |
Should have added. Engine temp doesn’t appear to make a difference to the behaviour.
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 168 ![]() ![]() ![]() |
Definitely pull codes first. The warning light does not come on for every code.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
As above, check for codes first. If there are no codes it could very well be a VCV issue.
WestCountryBob Member Since: 04 Jul 2023 Location: West Country Posts: 10 ![]() ![]() ![]() |
Thanks for the replies.
Just ran some diagnostics with an OBDLink MX+ and their OBDLink app - no fault codes returned! Can’t decide if that’s good news or bad! ![]() I was kind of hoping it would be the MAF sensor or another 5 minute job. I then ran ‘CarScanner’ which returned: ![]() Click image to enlarge Third app (FORScan Viewer) also returned no errors. So I’m baffled now! |
I'm a retired 35 year mechanic but I not an expert on Puma injection. Myself, I would check your battery connections and ground connections (as many as you can find), clear the codes, and try again. Reasoning? The fact "everything" was having trouble communicating leads me to think there's probably a common cause. The most common connection issue is grounds.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 635 ![]() ![]() |
Those are old archived codes and not likely to be relevant to your current issue.. More likely from previous work and having something disconnected.. As said make a note and clear.. If the same return then you will know one way or other
If you could run your truck while watching live values, Fuel rail pressure would be a good one to start with.. 👍 |
Thanks all for the info. I’ll get some live data when I’m next out and feedback here.
Live diagnostics in hand, I went out for a drive today. Made sure I did plenty of stopping and starting. Did it misbehave? No, of course not
![]() I’ve cleaned the MAP sensor as that was coated so let’s see how it behaves. |
