![]() | Home > General & Technical (L663) > low speed stuttering |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2703 ![]() ![]() |
Is it like a brief hesitation when pulling away at a slow speed, for example accelerating off a roundabout or away from a queue?
Mine had this, it was the exhaust manifold pressure sensor that was causing it. There is a thin tube which feeds the sensor and it blocks with soot over time. The dealer changed the inlet manifold sensor first but this didn’t fix it. I posted a thread on this forum with the error codes. |
D200 3 litre Member Since: 26 May 2024 Location: huntingdon Posts: 3 ![]() ![]() |
its more of a spluttering than a hesitation
makes the pull away jolty but could be the same fault i've not looked at error codes, are they easy enough to see? is there a link to your thread |
You’ll need a compatible reader to see the fault codes. I use a GAP IIDTool.
Thread is here: https://www.defender2.net/forum/topic90462.html Don’t worry about your warranty, if the fault occurred before it ran out then they will still fix it even if it runs on beyond the end. |
sounds like the same fault to me, i'll let the garage know when i drop it off
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 516 ![]() |
There is a known gearbox glitch when you're slowing down close to a stop, then decide to accelerate again. Like you're slowing for a red light then it changes just before you completely stop. You push the accelerator and the car jolts forward..
I asked LR assistance and they told me it may be a software issue. |
