Home > V8 > Land Rover 110 V8 cast manifolds to Range Rover conversion |
Electron Member Since: 28 May 2016 Location: Bideford Posts: 31 |
This is the crossmember in showing the gaps each end for the down pipes ...
Click image to enlarge |
25th May 2024 1:13pm |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 195 |
This is a good mod - I connected mine to a TD5 system, much bigger bore and a sensible increase in noise.
Once done it's worth swapping the needles in the carbs for BBW, that gives a huge improvement in drivability. https://www.defender2.net/forum/topic72326.html 90 V8 CSW - 1988 |
4th Jun 2024 10:56am |
I'm going for these manifolds, Weber 500 downdraft, MegaJolt with the manifild pressure advance and a temperature sensor choke. I'm also sticking a lambda sensor bung somewhere so we can then do a rolling road final tune once we've run it a bit.
6th Jun 2024 8:24pm |
Have you thought about one of the Holley Sniper or FiTech injection systems? 90 V8 CSW - 1988
11th Jun 2024 10:51am |
Looked at going the full fuel injection route but had quite a lot of other "stuff" to get done. I have a Thor manifold and injector rails ready and waiting. At least with the MegaJolt I'm half way there ....
14th Jun 2024 5:02pm |
