Home > V8 > Land Rover 110 V8 cast manifolds to Range Rover conversion
Electron
Sorry been lurking for a while but now a good way into my 110 V8 (1985) rebuild and improvement. I'd read about moving to Range Rover cast manifolds but never found a post with all the bits photographed. For mine I needed the two cast iron manifolds + two down pipes + Y piece but I also needed to change the gearbox crossmember.
Old Manifolds + Downpipes
New Manifolds + Downpipes
Crossmembers
Post #1035681 25th May 2024 11:35am
Electron
This is the crossmember in showing the gaps each end for the down pipes ...
Post #1035685 25th May 2024 12:13pm
Ranger 6
United Kingdom 1988 Defender 90 V8 Petrol CSW Rimini Red
This is a good mod - I connected mine to a TD5 system, much bigger bore and a sensible increase in noise.
Once done it's worth swapping the needles in the carbs for BBW, that gives a huge improvement in drivability.
https://www.defender2.net/forum/topic72326.html 90 V8 CSW - 1988
Post #1036452 4th Jun 2024 9:56am
Electron
I'm going for these manifolds, Weber 500 downdraft, MegaJolt with the manifild pressure advance and a temperature sensor choke. I'm also sticking a lambda sensor bung somewhere so we can then do a rolling road final tune once we've run it a bit.
Post #1036724 6th Jun 2024 7:24pm
Ranger 6
Have you thought about one of the Holley Sniper or FiTech injection systems? 90 V8 CSW - 1988
Post #1037092 11th Jun 2024 9:51am
Electron
Looked at going the full fuel injection route but had quite a lot of other "stuff" to get done. I have a Thor manifold and injector rails ready and waiting. At least with the MegaJolt I'm half way there ....
Post #1037470 14th Jun 2024 4:02pm
Electron
Fits beautifully
Post #1047110 28th Sep 2024 4:12pm
Linds Hanson
I have a pair of good 3.9/4.2 manifolds with good studs if anyone needs some?
Post #1047492 2nd Oct 2024 3:29pm
Electron
TD5 rear section fits physically but mounts are in the wrong place so I went for new chassis mounts so that I don't have problems with replacing down the line ...
Post #1049336 21st Oct 2024 3:32pm
Linds Hanson
Land Rover do a bolt on mount for there
Post #1049450 22nd Oct 2024 2:56pm
Ranger 6
Electron wrote:
You won't be surprised to hear that mine has some impact damage on those lower exhaust pipes.... Laughing 90 V8 CSW - 1988
Post #1049545 23rd Oct 2024 1:46pm
