Home > Td5 > Defender 90 handbrake adjustment access issue
cookiemonster
United Kingdom 1999 Defender 90 Td5 CSW Aintree Green
Hi sorry this is such a basic question for most of you but I’m young and learning and trying to get on to my handbrake adjuster bolt but the bracket for this large lump as I pointed to I. My photo is in the way to be able to get a socket with extension on. I’ve tried a knuckle but still can’t get in. Firstly what is this large lump in my photo it just looks like a block of steel and does anyone know a tool that lets me access the bolt adjuster please or finish have to remove this bracket ?
In the photo it looks clear but honestly it’s masked by the bolt head
If I’ve done it right the photo is in the gallery
Any help would be appreciated
Post #1035517 23rd May 2024 8:14pm
Dinnu
Adding your photo.
That lump is used on Td5s and is a harmonic damper (reduces vibrations at certain speeds).
Certainly your adjuster bolt is not that accessible. I never had to adjust a handbrake with the harmonic damper on. Is your handbrake lever too high when engaged? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1035535 24th May 2024 5:18am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
I find a 3/8ths drive 17mm and ratchet is what works for me. Easiest way is to chock the wheels get a handy assistant to work the handbrake and then adjust into spec 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1035537 24th May 2024 6:33am
cookiemonster
Thank you both I now know what it does and I’ve gone and got a 3/8 socket set and I can now access don’t know why I didn’t think of this I only had 1/2” set.
So handbrake has only 3 clicks. First click it still free spins second click it’s start to bind and 3rd it stops it turning by hand. Yet mot said handbrake needs adjusting should I give it a little adjustment or is it something else I’m missing
Thanks again
Post #1035596 24th May 2024 5:17pm
Dinnu
3 clicks sound right to me. When adjusting, lift one of the rear wheels (assuming you have a standard open diff on the rear) and ensure that there is no rubbing sound coming from the hand brake when you spin the wheel. Would also be good to check drum not getting too hot after a short spin. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1035608 24th May 2024 6:50pm
jst
3 clicks sounds right.
3/8 socket sets do majority on a lr, Halford and bacho last well. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1035611 24th May 2024 7:10pm
