Home > In Car Electronics > Fuse box dramas
TheRonin
Australia 2012 Defender 110 Puma 2.2 SW Alaska White
Fuse box dramas
I have a fuse box that has been relocated to sit under the cubby by a previous owner, can someone please tell me the layout on this fuse box, i've looked at the layout diagram in the vehicle but it doesn't match.
I've got both the ABS & traction control lights on after having replaced the battery and need to check/replace the correct fuses.
thanks
Post #1034589 13th May 2024 6:41am
Martin
Site Admin
Thatโ€™s a standard 2.2 underseat fuse box. Should be a sticker under the seat box lid with the layout?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1034594 13th May 2024 7:06am
TheRonin
Thanks Martin, that help as didnt think to check under the drivers seat panel.
So i've check the fuses and they look ok. Any other thoughts to what could be causing the ABS/TC lights?
Post #1034600 13th May 2024 7:54am
A poor ground is possible, it can cause all sorts to happen.
Especially check the main ones. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1034602 13th May 2024 8:58am
