Home > Maintenance & Modifications > New battery Question
Stiff1
So battery the Series 3 arrived with not holding a charge.
It's just a Halfords own brand...
Went to just pick one up now and can get the same one, although updated to...
But they have this...
With higher capacity and a few pound cheaper.
Is there any reason not to go with the higher rating one, brands aside?
Thanks
Post #1033949 6th May 2024 1:06pm
miker
Nope. Can go as big as you like as long as it's 12v and fits in the hole.
Post #1033955 6th May 2024 2:23pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Yuasa batteries are pretty good we have them on a few of our cars pretty cheap with the Halfords trade card aswell 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1033968 6th May 2024 4:20pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
If your still using the std alternator its gonna be 35 amp or 45 amp, and that may not charge the bigger battery fully.
Bigger really isn't always best, if it was me i would get the best quality battery the series is designed for. 1953 80"
1987 mini city e
2011 90"
Post #1034123 7th May 2024 9:14pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
It will charge, but it will take a bit longer. This is only valid for.mostly discharged battery. With good battery it will be the same, because it will need to charge only the amount of energy used during starting of engine, and it is the same, or possibly lower, because bigger battery => more power for starter => faster cranking of engine => shorter starting time => less energy needed. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1034187 8th May 2024 4:25pm
X4SKP
Hello Stiff1
I have fitted these Silver 5000 Yuasa batteries to both our Defenders, + a Yuasa Leisure Battery to our Caravan.
They review well, have the extended warranty + if it works… and I have no reason to doubt it currently, a quick battery condition ‘window’… green good… red bad.
If you can get a Halfords Trade Card… 20% off Batteries… Thumbs Up SKIP
Post #1034231 8th May 2024 8:59pm
Devon-Rover
Bit late to the party.
IMO bigger is better.
Yes the 069 is a recommended battery and the 072 is just a bigger version.
You don't say if it's petrol or diesel?
Co-incidentally I've just replaced the battery on my Series 2a petrol.
https://www.tayna.co.uk/car-batteries/varta/g7/
The 249 will just fit inside the battery tray, just check which way round your + and -1 terminals are and remember that the terminals should be inboard so the bonnet stay can't short it out. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1034243 8th May 2024 10:25pm
It'll charge it just fine. One of my fleet has a 5.7 litre diesel engine which needs a 1200 CCA battery to crank, and a teeny-weeny dynamo to charge it. A much bigger mismatch but it works perfectly. That's how it used to be.
Post #1034245 8th May 2024 10:34pm
