Home > Off Topic > Metal Repair Tape
AMBxx
Metal Repair Tape
This relates to my lawn mower, so off-topic, but given I want to bodge a repair to metal, a Defender site looks like a good place to ask!
The cutting deck on my lawn mower is starting to rust through (tufts of grass sticking through the holes). Our problem is very stony soil and moles, so always sharpening/replacing blades.
Would something like this: https://www.amazon.co.uk/ADHES-Waterproof-...1&th=1
be worth a try? I just want to avoid spraying lumps of chalk all over the place and stop the deck falling apart.
Post #1033960 6th May 2024 2:22pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Any pictures to show the extent of the problem? Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1033965 6th May 2024 2:50pm
AMBxx
I'll get some tomorrow.
It's a line about 3 inches long wiht 2 or 3 small holes within that. You couldn't get your little finger through any of them.
It's on a bend so can't weld anything on to it (even if I had the equipment and ability)
Post #1033969 6th May 2024 3:55pm
Balvaig
There are plenty of two part epoxy putties to repair holes and cracks in metal. Probably stronger and longer lasting than a metallic tape.
I have used them for this sort of repair and if you can get behind the crack and holes you can add further reinforcement using aluminium mesh.
Post #1033970 6th May 2024 4:04pm
Down & Dirty
J b weld metal will sort that far better than tape and probably out last the rest of it Rolling with laughter
Thumbs Up My 24 HSE X-Dynamic 90 Carpathian Grey
Post #1033986 6th May 2024 6:25pm
As just above, unless the damage is large. But you can buy a new deck for about £90.
The motor / engine studs, and associated fixings if you change the deck could be a problem.
Such as shearing, due to age and fatigue.
At the least if you did attempt replacing the deck, I’d soak the fixings for days in penetrating oil like WD40, and go very easy undoing them by hand obviously with the spark plug removed as well.
I presume the decks are available for the one you have of course. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #1033999 6th May 2024 7:56pm
Ianh
Quiksteel is also a good epoxy putty for those sort of jobs as well.
Post #1034002 6th May 2024 8:34pm
AMBxx
Thanks all for the feedback. I wasn't sure that epoxy resin stuff would work on a thin layer of metal. I've only used it for holes before and not in metal.
Yet another item on my to-do list.
Post #1034030 7th May 2024 6:12am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
My Honda Isy cutting deck rusted through, it didn’t make any difference to the cutting performance so I didn’t see a need to repair it.
I eventually replaced it for a 16” John Deere mower thinking John Deere would be good. Big mistake, it was rubbish compared to the Honda Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #1034035 7th May 2024 8:12am
AMBxx
I have the same Honda. Given how stoney our ground is, I'm worried about breaking windows - the windows by the grass are down to the floor!
Post #1034036 7th May 2024 8:14am
Zed
It sounds like a decent machine so I’d say it’s worth buying a new deck. Try to keep it clean after use and it’ll last years. Plus a new deck will be cheaper than a window or someone’s eye! WARNING.
Post #1034053 7th May 2024 11:51am
Honda Izy is good, that’s what we have. Currently on its 23rd annual season and starts first time.
So 2001 to date is incredible I think! Play Stupid Games, Win Stupid Prizes.
Post #1034070 7th May 2024 1:48pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I still use a Honda that my father bought new in 1987.
Still starts first pull, maybe second after its winter holiday!
Only on its third blade, still leaves nice stripes…!
Post #1034122 7th May 2024 8:14pm
