![]() | Home > V8 > A note about oil filters |
Jimbob292 Member Since: 06 Nov 2023 Location: Derby Posts: 21 ![]() ![]() ![]() |
Yes, its a big issue, i only use ERR3340, on my 3.9EFI.
Stripped a few down and even seen the cartridge squashed, creating more of a restriction. Dam Chinesium filters! Best mod i ever did was the stiffer spring in the oil pump, (serpentine engine) it pushes up the pressure to the rear end of the block, helps the tappets & cam from wearing out prematurly. Ray & V8 Developments helped me out heaps. I use 20/50W VR1 Valvoline, expensive, but it has all the right additives for flat tappet engines. |
