Home > General & Technical (L663) > 7 Seat load space under floor Cavity?
XplusYplusZ
Has anyone removed or seen the removal of the polystyrene jack holder in the cavity below the loudspeaker floor panel in a 7 seat 110? It seems like there’s quite a lot of space taken up by pretty redundant Polystyrene, however, it doesn’t seem to come out easily and I can’t tell if it’s clipped or glued, and if it is worth taking out to store some tools etc below the floor panel?
I have a large jack and a big tool kit if love to store away for emergencies only.
Post #1032300 21st Apr 2024 11:19am
Mark1107
United States
Take it out. It’s rubbish. I took mine out and generated more room. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1033915 6th May 2024 12:01am
XplusYplusZ
Is it just glued in or clipped?
Any tips for getting it out? Mine is pretty well stuck in.
Do you have a pic of the space!? I imagine it’s quite a bit of extra room for tools/jack
Post #1033941 6th May 2024 11:40am
snowtiger
Germany
It is not glued, just a tight fit.
I removed it to delete the cup holder on the right panel in the back. It was quite hard to get it out, maybe it only worked because the floor cover was already removed.
Post #1033995 6th May 2024 8:40pm
The Phantom Menace
Belgium
There is indeed quite a bit of unused space on the left side. On the right are the batteries of my MHEV. It was not easy to remove the polystyrene jack holder thing. I removed it by hand by pulling the 3rd row up a bit and sliding the polystyrene jack holder from left to right. I ended up breaking the polystyrene jack holder thing in the middle so that the battery portion (right side) is still covered and can provide extra support for when I'm loading something into the trunk.
I was able to store the following items under the trunk floor:
- kinetic rope of 9m long.
- 2x soft shackle.
- folding camping shovel with saw blade.
- jack
 Spec: Land Rover New Defender 110 X-Dynamic SE - P400
Post #1036761 7th Jun 2024 12:36pm
XplusYplusZ
Nice! Thanks for sharing. Were there any clips/glue holding the polystyrene in place, or is it just a snug fit?
Post #1037094 11th Jun 2024 11:09am
