![]() | Home > General & Technical (L663) > 7 Seat load space under floor Cavity? |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 75 ![]() ![]() |
Take it out. It’s rubbish. I took mine out and generated more room. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 516 ![]() |
Is it just glued in or clipped?
Any tips for getting it out? Mine is pretty well stuck in. Do you have a pic of the space!? I imagine it’s quite a bit of extra room for tools/jack |
snowtiger Member Since: 06 Oct 2022 Location: Bavaria Posts: 31 ![]() ![]() |
It is not glued, just a tight fit.
I removed it to delete the cup holder on the right panel in the back. It was quite hard to get it out, maybe it only worked because the floor cover was already removed. |
The Phantom Menace Member Since: 15 Feb 2024 Location: Antwerp Posts: 11 ![]() ![]() |
There is indeed quite a bit of unused space on the left side. On the right are the batteries of my MHEV. It was not easy to remove the polystyrene jack holder thing. I removed it by hand by pulling the 3rd row up a bit and sliding the polystyrene jack holder from left to right. I ended up breaking the polystyrene jack holder thing in the middle so that the battery portion (right side) is still covered and can provide extra support for when I'm loading something into the trunk.
I was able to store the following items under the trunk floor: - kinetic rope of 9m long. - 2x soft shackle. - folding camping shovel with saw blade. - jack ![]() Click image to enlarge Spec: Land Rover New Defender 110 X-Dynamic SE - P400 |
Nice! Thanks for sharing. Were there any clips/glue holding the polystyrene in place, or is it just a snug fit?
