![]() | Home > Tdi > Battery for 200 tdi |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
its not the correct battery for the truck and doesn't look to be fixed in place either
you have a couple of options go back to the correct one, fit a twin battery set up , or maybe modify the battery box itself as some of the aftermarket ones are flat floor and allow for some different positioning of batteries and extras. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8222 ![]() ![]() ![]() |
As Darren eludes to move it through 90 deg and reposition some of the other stuff. Cheers
I believe the factory original battery was a 072 which has dimensions of 266L x 175W x 220H.
It was very very common that these were "upgraded" to a 110 battery which has dimensions of 317L x 175W x 175H. The reason was the bigger capacity and sometimes better CCA. It looks like yours might be bigger than a 110, unless it is sitting on something. Your battery is 329L x 171W x 240H so the additional height and length is your problem. |
RevRon Member Since: 31 Mar 2024 Location: Scotland Posts: 2 ![]() ![]() ![]() |
Thank you all for your advice.
I will order a new battery for now, long term I think I will go down the duel battery route. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
I use an 019 battery. They were standard fit in my 2008 and 2011 Pumas. Have fitted them to a 200 tdi and my daughter's 300 tdi. As yours is a 200 tdi do not go for one of the newer type batteries. The charging system was not designed to charge high enough for them so they will go down over time. I use a Halfords 019 in my 200 tdi.
My battery fits in that position so just push it forwards. Your retaining metal arms will only fit in that position as that is where the slots are for the hooked ends. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Joeytf Member Since: 20 Sep 2024 Location: Somerset Posts: 12 ![]() ![]() |
Mines a 019
