Home > Technical > Puma 2.2 DPF query |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
I would suggest getting an obd reader and it should tell you status of dpf. It will also show you the cat/dpf temperature and you will know it is regenerating as the temperature reaches around 600degC.
29th Apr 2024 6:38pm |
Gal Dove Member Since: 22 Jan 2022 Location: South Wales Posts: 74 |
Hi Scotm.
Thanks for the recommendation. I'm not sure that I at that point yet but have looked around and spotted a few OBD readers - notably the Vgate iCar Pro - but according to Amazon it's not a comparable device with the Puma. Are you able to point me at another Defender friendly one? |
29th Apr 2024 7:19pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
I use an ELM327 and Car Scanner on smart phone. I could check the dpf load on mine which was showing as 40%. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
29th Apr 2024 7:25pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 591 |
You might try downloading the torque pro app.. When I had a dpf I'm sure it was capable of displaying at least a couple if not the three exhaust gas temp readings..
I don't remember seeing any readings for the differential pressure sensor.. But still a worthwhile few pounds for the pro version👍 |
29th Apr 2024 7:27pm |
Thanks for tye suggestions so far ….this is assuming that this is a DPF issue or that the engine is attempting to cycle a re-gen?
I’m on iOS so I’d ideally need a OBD reader that is compatible- but I’d only bother buying one if there is some sort of issue which I’m not sure there is? Maybe it’s just my driving style and mileage? Is anyone able to confirm the engine sound and behaviour that I described as being those of a DPF cycle? |
29th Apr 2024 8:15pm |
When I had standard exhaust, on a 90, I could not detect when it was doing a regen. However when I replaced with a straight through mid section, I can hear a change of tone in the exhaust which I also attributed to a regen cycle. The engine feels a bit more responsive too during regen.
The ELM327 I referred to connect via wifi to an iphone. Downloaded Car Scanner from app store. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
30th Apr 2024 1:01am |
Petronius4 Member Since: 07 Oct 2015 Location: Somerset Posts: 94 |
Plan a day trip, get on the motorway and drive non stop (averaging 50+ mph) for an hour turn around. Repeat. This will give the DPF chance to deep cycle and work its magic. -------------------------------
👲🏻 1986 ex-Military 90 NAD 2.5 Soft Top. Sold 🇬🇧 2015 Defender 90 - Ripon Landrover Heritage 006 |
30th Apr 2024 11:10am |
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 51 |
The only time I know the DPF is going through a regen cycle is when the orange indicator light shows on the dashboard. I don’t notice any change in exhaust sound. 2012 90SW - 2.2TDCI
30th Apr 2024 2:20pm |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 199 |
I have never seen any light on the dash, nor noticed any difference in engine noise. But I can detect a difference in exhaust smell if its still running and I have popped out to get something out of the boot. Acrid. I presume that's the DPF doing its job. (I have read somewhere that if its clogged then it needs to cleared by the garage - but maybe thats incorrect).
30th Apr 2024 3:35pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2099 |
There is no visual indication on the dashboard to tell you the DPF is going through a regeneration. The amber light you are seeing is a warning light, telling you your DPF is over full and the vehicle needs to be immediately taken on a long high speed run to undertake and complete an active DPF regeneration. If this is not done soon then the red DPF light comes on, and I believe limp mode is activated. At this point a static forced regeneration needs to be implemented with diagnostics tools, which in some instances still do not clear the DPF and specialised DPF cleaning or potentially a new DPF is required. |
30th Apr 2024 6:02pm |
You are correct, my mistake, the amber warning indicates that the particulate filter is nearly full and you should proceed to drive such that the auto regeneration process commences and not that it is actually in process.
My amber warning light illuminated last week as I was leaving the channel tunnel but, with 300kms of autoroute driving at a steady 100kms/hr, there was no indication of a change in the exhaust sound whilst the regeneration was in process. The truck goes in for its annual pollution check next week and I will then be told how effective it has been! 2012 90SW - 2.2TDCI |
30th Apr 2024 6:34pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 388 |
I notice a definite engine change note during the regen. I use an ultragauge on the dash and this shows the temperatures as they rise and fall. I bought my car new in 2015 and is a daily driver. Never had a dpf light on and I change the oil every 6000 miles. But certainly the system does regen about once a week. I do about 200 miles in that week. Total mileage now is 94000. 2015 90 XS Santorini Black
2nd May 2024 8:05am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
As for correctly reading the oil dip stick try my patented, forum-approve method :
don't insert it fully, leave it out by 20mm, then the oil level will be inside the waffle section; max should be 20mm below the top end, easy so see an overfill; also when you insert the stick have the waffle pattern face towards the engine to avoid scrubbing oil off the pipe https://www.defender2.net/forum/topic79934.html (down the page) |
2nd May 2024 9:16am |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 |
Digging up an older thread.
I was wondering on the health of my DPF and plugged in my OBD dongle and using Car Scanner LM yet I don't seem to see anywhere where I can see this. Any tips on where in the app this would be? Many thanks P |
21st Sep 2024 3:07pm |
