![]() | Home > Modifications & Maintenance (L663) > Deployable tow bar retro |
Looneyfitter Member Since: 03 Mar 2024 Location: Liverpool Posts: 30 ![]() ![]() |
Brilliant thanks mate. OK so it seems that my coil variant should. Bolt on then as it looks exactly the same as yours. Thanks again pal |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3011 ![]() ![]() |
l've got the fixed/removable tow ball on my 90 Commercial (coil springs) and have never once bashed my shins on it.
l never remove the tow ball although l've tried the remove/replace a couple of times to make sure it works. |
OK so bit of an update. I've fitted the deployable. Bar today. I an confirm the spring tow bar also fits air suspension. Not sure why there's two diff part numbers?
Can anyone with deployable tell. Me. If you can deploy from the touch screen? I don't have the switch for the boot yet so can't test. Ive searched through my ccf and can't find anything to add a button on the screen. Would anyone mind sharing there ccf if you have the deployable. Tow bar please? If enabled the items I can find but would lime to double check. Cheers Gareth ![]() Click image to enlarge |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1235 ![]() ![]() ![]() |
Yes…the tow bar can be deployed from the GUI.
In addition the rear view camera shows it when reversing to allow perfect alignment Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
Don't suppose you have gap do you mate so can post your ccf?
I've reset the pivi a couple times and now have tow bar on the gui bit I get a warning saying tow bar not secure do t tow. Reset using switches. Obvs can't as I do t have them yet
monyett Member Since: 10 Dec 2024 Location: Nottingham Posts: 1 ![]() ![]() |
I'm looking to fit the deployable to my 110. Can you list the modules, wiring etc required please? Air suspension too
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 60 ![]() ![]() |
You guys in Europe get the dinky tow hitch. In australia we get a thick, towing tongue. 💪
eno Member Since: 15 Apr 2024 Location: Qld Posts: 41 ![]() ![]() |
And that is probably because Australians generally seem incapable of loading trailers properly. So higher ball weights have to be assumed, and probably even in excess of the higher allowances. 😂
