Home > Puma (Tdci) > Replacing standard front bumper- which to go for?
glpinxit
The rust on the [standard] front bumper on my 2014 XS has reached the stage where I'm planning to replace it. I want one that still looks standard but doesn't suffer as badly once the coating has been blasted by the front wheels (and I'm not in the market for the front shield from Mr Lewis). I need one with holes for the end caps but that doesn't seem to reduce the available range.
I'd originally planned to buy a galvanised bumper and spray it satin black. But now I've seen Craddocks do a 'powder coated over zinc' bumper (DPB501190PMAV). Has anyone any feedback on this? (Or advice that doesn't suggest repainting the existing one.) Cheers, Guy.
Post #1033018 27th Apr 2024 8:22am
Zed
Stainless from Uproar4x4.
https://uproar4x4.com/collections/stainless-steel-front-bumpers WARNING.
Post #1033019 27th Apr 2024 8:25am
Dinnu
Quote:
Powder Coated Over Zinc Phosphate Undercoat Over Zinc Passivate
It is an improvement over the original Land Rover bumper painting process, however if you want better, stick to your original plan, buy a britpart galvanized bumper - it is remarkably good, and then paint it with your choice of paint. Just remember that zinc needs a bit of more preparation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1033020 27th Apr 2024 8:38am
Linds Hanson
Uproar
Post #1033029 27th Apr 2024 9:29am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
The current one lasted ten years? Stainless costs hundreds (and equally likely to be accidentally damaged)?
Buy the cheapest possible, paint it black if not already, replace it as and when, and think of the front bumper as a "consumable".
Peter
Post #1033032 27th Apr 2024 9:51am
geobloke
Re: Replacing standard front bumper- which to go for?
Well Yikes, sounds like a Giggle of a back story there Rolling Eyes
Post #1033036 27th Apr 2024 10:07am
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
Id get a galvanized one and paint it.
Bumpers take abuse from all sorts - not only actual landrover use, but also people in car parks etc.
You can't touch up a powdercoated unit. You can a painted one.
Powder over non galvanized is a very temporary solution too. One stone chip and the water gets in behind and delaminates the powder over time.
Post #1033037 27th Apr 2024 10:21am
Ianh
I bought a Black powered coated quad DRL bumper from Manor automotive. They also do a twin DRL and a plain NO DRL bumper. The plain one is £240.
https://manorautomotive.co.uk/products/lan...eel-bumper
I checked with them and they stated it was 316, not 304 grade stainless steel. So extremely resistant to corrosion. The steel is 2.5mm thick and the bumper has holes for end caps.
Like others I’m not a fan of powder coating, however if stone chips do happen then the 316 should not corrode and blow the powder coating. Time will tell if I’m correct.
Before fitting I sprayed the back, insides, and bottom of the bumper with Bilt Hamber Dynax UB wax for added protection.
Then used Bilt Hamber double speed wax on the front and top to protect the visible black powder coat.
To refurbish the rubber end caps I gave them a good clean with Meguiars APC, diluted 1 part APC to 10 parts water. Then coated with car plan black trim wax. An old school product but works really well on End caps, mud flaps etc. The end caps looked brand new after this.
Post #1033049 27th Apr 2024 2:41pm
LR90XS2011
Try Wildbear.
Not as good fit as original but surprisingly good price for standard style in stainless.
Don't buy if you have standard rubber A bar and don't like tweaking things to make them fit, the Wildbear one sits about 8mm further forward so A bar brackets wont fit.
https://wildbear4x4.com/collections/defender?page=6 DEFENDER 90 TDCI XS,
Post #1033072 27th Apr 2024 6:13pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I'm on my 4th bumper and went for galvanized this time. I actually like the look as opposed to painted.
 Euro-Leafing to infinity and beyond.....
Post #1033290 29th Apr 2024 5:53pm
I think that suits yours, it looks just right with the grill and headlight sounds colour matched. No Guts, No Glory.
Post #1033335 29th Apr 2024 10:00pm
glpinxit
Thanks for all the comments and suggestions.
I've decided to go with galvanised (I found a 3mm version at a reasonable price- apparently standard is 2.5mm). I'll see if I can get it powder coated locally. And contrary to what I originally said, reading more carefully it looks like fitting the front wing mud shields won't involve drilling so I'll get some https://gwynlewis4x4.co.uk/product/gl1022-...d-shields/ (I already have others elsewhere) Cheers, Guy.
Post #1033406 30th Apr 2024 3:13pm
BrunoJ
Norway 2012 Defender 110 Puma 2.2 SW Keswick Green
I was in similar situation with front bumper (as well as roof rack) but decided to give them another chance. So cleaned and repainted. Checking closely you can see some places are not ideally flat like from the factory, but overall good result. That was combined with bigger de-rusting service (frame protection, replacing bolts etc). I had to replace side bars/steps, it was too late to try to restore them.
I'm not sure this bumper will survive another 10 year, but after one year I do not see any issues.
I'm not sure it that matters, I have a winch installed, so potentially not all 3rd party bumpers will fit in my case.
Post #1033417 30th Apr 2024 4:51pm
strang
Thanks Thumbs Up Euro-Leafing to infinity and beyond.....
Post #1033426 30th Apr 2024 6:22pm
Stacey007
I needed one after around 8 years, managed to get another standard one and sprayed it gloss black.
total around £80
I was looking at the uproar ones a while back and a plain one I thought was around £300 shocked to just look now and a plain one is £550 and if you want lights £750 to £1200
They have shot up?
Just looked and a new basic black bumper £110 with end caps. I could flat this down and respray in gloss, buy 5 bumpers for the same price..
https://www.sp-4x4.com/product_p/jwp1084.htm
Don't get me wrong I like the uproar stuff but that's a lot for a std bumper...
without end caps even cheaper...
https://www.sp-4x4.com/defender_90_110_fro...104270.htm
Post #1033496 1st May 2024 9:58am
