Home > Td5 > Steering wheel vibration /shake
110Urb
 2016 Defender 110 V8 Petrol Adventure Auto Corris Grey
New to me 90 and for the most part it's absolutely fine. However on occasion, I notice a vibration /shake? through the steering wheel when cornering at speed (think more sweeping merging lanes or large roundabouts rather than precision circuit driving Laughing )
Would the steering damper and panhard rod be potential / major culprits here?
Other than the above scenarios it drives around fine.
Post #1032903 26th Apr 2024 9:12am
geobloke
If it is only happening when changing lanes (not when driving straight) then it is likely to be one or more bushes has worn. Unfortunately there is no "it is this particular bush that is worn" as it is likely all of them are worn (or loose) and the wobble is accumulative.
As a first step, get underneath and re-torque all the bolts/nuts that relate to bushes: Radius arms, lanyard rod and steering damper. Also check your tyre pressures are equal left to right, should be around 28psi. Whilst you are there check for play in your track rod ends and wheel bearings as these could also cause a wobble.
If the problem persists then as a second step replace all the front end bushes. Then the damper. It is almost never the damper itself but its bushes. Unless of course it is leaking oil everywhere.
Investigate first before throwing parts at this problem. Thumbs Up
Post #1032912 26th Apr 2024 9:37am
excossack
I found I had some play (still have but not as bad) and my steering damper bush had worn. Also the steering drop arm nut had come a little slack. These have helped. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1032918 26th Apr 2024 10:21am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As geobloke says… get under and have a look. Usually with that age I’d suspect panhard rod bushes first but it could be radius arm bushes, and bunch more stuff too?? Tie rod ends etc.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1033169 28th Apr 2024 5:28pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
It could also be the hubs are to floppy and need tightening with a spring balance. The swivel pins.
Post #1033184 28th Apr 2024 8:49pm
Procta
id check the wheels for balancing too, just in case something has threw a weight off a wheel.
i had a problems too at a high speeds etc, and me and my dad put mine on a jack to check if there was play in anything, before i threw money at it. We found Censored all wrong, just the front wheels needed a re balance. One was far worse than the other, so it might be worth getting those checked 1st, as its a simple job, then follow what the lads have said. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1033837 5th May 2024 2:54am
