Home > Puma (Tdci) > HELP !!!! immobiliser issue |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2079 |
So from what you have written your engine cranks ( starter turns) but does not start. You have a 2009 90 Puma. Your garage suspects the vehicle alarm system is immobilising the engine.
1.your alarm unit will be a Lucas 10AS. A Green unit visible if you remove the drivers footwell speaker and look up through the aperture. 2. On your 2.4 the communications wire from that 10AS goes to the instrument cluster , through the instrument cluster and then on to the engine ECU. 3. The key fob on your key ring interacts with a transponder coil around the top of the ignition barrel , this energises the fob after you switch on the ignition, and gets the 10AS to send the de-immobilisation code to the engine ECU. So if you suspect the vehicle is immobilised. 1.Check the 3 fuses that serve the 10AS. If ok. 2. Change fob battery ( cr2032), resync fob ( with doors closed press fob lock button 4/5 times quickly then the fob unlock button once. Doors locks should open to indicate sync has worked If vehicle will still not start 3.Remove the instrument cluster and disconnect the connector going to it. With a piece of wire bridge pins 3 and 4. With the instrument cluster still disconnected attempt to start vehicle. If it starts the issue is in the instrument cluster and Martin, site owner , can fix that via his busines, or you can remove pins 3 and 4 from the connector and join them together, then refit connector and cluster. If vehicle will still not start and 10AS is still the suspect. 4. Remove 10AS and send to technozen for test / repair. https://www.technozen-electronics.co.uk/la...-services/ Of course it may not be the vehicle immobiliser, it could be the the camshaft position sensor or the crankshaft position sensor but I’m assuming your garage has ruled them out. |
24th Apr 2024 12:37pm |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 123 |
Wow thank you for such a detailed response Ianh ,haven’t heard back from garage will keep you posted
25th Apr 2024 8:28am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 847 |
If it is definitely the immobiliser and you want a permanent solution. I stumbled across this service when browsing.
https://www.empiretuning.co.uk/product/def...r-removal/ 2008 2.4 110 Utility Station Wagon XS. |
25th Apr 2024 11:24am |
If the 10AS is faulty you can do several things.
1.Get it repaired by the likes of technozen. 2.Buy a used working one off an auction site / breakers ( need correct version, some have central locking , some don’t, but the latter can be upgraded to support central locking for £45.) then program with diagnostics tool, I.e Nanocom. 3.Buy an alternative one from remotekey 4. Buy a new ALM DHxxxxx unit (10AS replacement) from a Land Rover dealer and have them install it. This is a very expensive option. 4. Decide to have immobiliser mapped out of the ECU by Bell auto services or empire tuning etc. And then replace with an aftermarket immobiliser or immobiliser/ alarm or immobiliser/ alarm / central locking. If you want to keep things simple and low cost, and it is deemed that the 10AS is faulty, then a repair would seem the easiest option. |
25th Apr 2024 11:47am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 |
When you get your hands on a Nanocom, disable Arm on lock, Plip immobilize and Key mobilize. You will have a simple central locking controller now. Should start.
25th Apr 2024 1:17pm |
Otis90 Member Since: 28 Jan 2017 Location: suffolk Posts: 14 |
I have had a similar issue, indie has said it is the 'no longer available' module and not wanting to fit the entire replacement system.....got a quote from Landrover Norwich £2046!.
Had chats with Clifford installers and Ghost and all happy to fit but not until the existing hard wired is by passed. Defender owner since 2007 2003 90 td5 'Otis' 2010 110 puma 'Rocky' |
4th Jun 2024 2:11pm |
is yours a green 10AS unit or a black ALM CHxxxx or DHxxxx unit ? . If green 10AS contact Technozen to see if it can be repaired.
If An ALM CHxxxx unit contact remotekey regarding possible repair. If can’t be repaired or ALM DHxxxxx unit talk with remotekey or IRB regarding a replacement at circa £400- £500 Edit. Adding links to companies Technozen https://www.technozen-electronics.co.uk/la...-services/ Remotekey https://www.remotekey.co.uk/shop/land-rove...trol-ecus/ IRB developments via their integrated316 site , noting IRB are a site sponsor and member Porny on here. https://www.integrated316.com/store/p/defe...ent-module Last edited by Ianh on 4th Jun 2024 4:39pm. Edited 2 times in total |
4th Jun 2024 4:06pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
As well, https://www.m1n1.de/en/bypass-land-rover-l...mobilizer/ Puma 110" SW
4th Jun 2024 4:15pm |
Otis90, which of your vehicles is having the issue, the 2003 90 td5 'Otis' , or the 2010 110 puma 'Rocky' ?
Both are most likely to have the green 10AS unit unless it was changed out at some later point. If it’s the Puma 2.4 has the indi done the Instrument cluster bypass test as I’ve highlighted above ? Have they attempted a resync between 10AS and engine ECU ? |
4th Jun 2024 5:24pm |
Hi there, its the Puma that is the problem. it is the green module though. They haven't done the cluster check and seem reluctant on both sides to do more. The issue originally was made worse on cold days in winter so they advised we do the pre warming coils which did cure my air intake leak as a bonus as they replaced all the seals to get to the coils but obviously had no impact on the not starting, they then re programmed 2 new fobs and coded which worked for a month then it started to play up so I am about £1200 down and counting. I have reached out to your suggestions on who can help look and test the module. That seems the best option left. Defender owner since 2007
4th Jun 2024 5:41pm |
I think ruling out the instrument cluster is the next step, it’s not hard to do, you can do it yourself. It’s just a couple of screws to remove the cluster, then detach the single loom connector from the cluster, then on that loom connector use a paper clip or similar piece of wire to connect pin 3 to pin 4, these pins have a light green with silver stripe wire to both of them. With the cluster disconnected then see if the engine will start. If it does it’s the cluster issue, if not it rules the cluster out so you can then get the 10AS tested / repaired by technozen.
5th Jun 2024 1:56pm |
Thanks for the detailed steps, picked it up this afternoon from the indie he is convinced its the ariel side of the module and needs extending, but since the fobs work fine not sure why it could be that in relation to the key not being recognised. They hadnt done the cluster test. Defender owner since 2007
5th Jun 2024 4:13pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
I can sort this very easily if you sent me the engine ECU... one of the most common things I do on a Puma.... IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
5th Jun 2024 5:16pm |
When your indi state aerial, like you I’m assuming they mean the 10AS antenna ( Orange with grey wire) used to pick up the radio signal from the key fobs for central locking / unlocking / alarm arm / disarm. So as you state if the fobs work ok for central locking and alarm it’s not that antenna. For the immobiliser it’s as I stated in my first post point 3. The key fob on your key ring interacts with a transponder coil around the top of the ignition barrel, this coil is connected to the 10AS and energises the fob after you switch on the ignition, and gets the 10AS to send the de-immobilisation code to the engine ECU. Noting the fob needs to be in reasonably close proximity to the ignition switch, I.e ideally on the same keying as the ignition key. |
6th Jun 2024 11:57am |
