Home > Puma (Tdci) > 2016 defender steering wheel
arran jones
Hi there,
Next mod is to replace the standard steering wheel on my 2016 defender 110.
I cant see any obvious places where to unbolt this one from? Pls could someone help?
Also im guessing i have to take it off to know which spline wheel to get next or is there a way of knowing before hand?
Many thanks 😊
Post #1032149 19th Apr 2024 2:45pm
camelman
Be careful when you're doing it that you don't move the DSC sensor ring as it is a pain to get back in sync afterwards and might mean a trip to a garage with the ODB kit to reset it.
If you gently lever the centre 'pad' up, it will effectively hinge up and give you access to the steering column nut.
Post #1032153 19th Apr 2024 3:46pm
Keep the nut on slightly loose also when you go to take it off so it doesn’t hit you in the face.
There is a torque setting for the nut in the WSM.
The splines are small, so a pain to count a little pointed tool is useful.
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1032162 19th Apr 2024 4:59pm
Ianh
You can remove the nut and count the splines without removing the steering wheel. Yours should be 48.
See https://www.web-rover.co.uk/articles-steeringwheels.html.
Nut torque is 43Nm, 22mm socket, a thin walled 6pt is best.
But, as others have said, you need to be very careful when removing the wheel and Changing it as even slightly disturbing the DSC sensor ring can require the system to need recalibration with appropriate diagnostic tools.
Post #1032182 19th Apr 2024 8:46pm
arran jones
Thanks all,
Is the dsc ring an obvious thing to see so i would know what it is?
Post #1032189 19th Apr 2024 10:02pm
camelman
Its a small plastic ring, try and keep it in it's original position
Post #1032190 19th Apr 2024 10:11pm
Ianh
This video explains all. The unit on the left with the blue plastic ring is the ring non DSC Puma owners see when removing the steering wheel. The unit on the right with the grey plastic ring is for DSC Puma’s. You will see the grey plastic ring when you remove the wheel. Do not be tempted to rotate it.
https://www.google.com/url?q=https://m.you...P_QW192DQV
Ps. How can I embed a video in my posts, rather than add a link ?
Post #1032194 19th Apr 2024 10:36pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Yes don't rotate the sensor unit like I did in the video 😂 LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1032209 20th Apr 2024 9:24am
