![]() | Home > Puma (Tdci) > Puma 2.2 Loss of power with Fault Codes |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 635 ![]() ![]() |
I have no experience of your issues but on my 2.2l I do know the tpp sensor has two potentiometers.. Each has its own supply and output to the ecm.. They have a common earth..
Its signals are used to tell the ecm the pedal position and direction of travel.. They are also tied in with brake switch by way of a plausibility issues.. Your shots of the pedal position sensor to me flag up that on the third set of values that the pedal position signal doesn't change much from the second shot even though you say it is pressed further..there may be an issue with the potentiometer track.. I sometimes view my two outputs when running torque... One starts at about 34% and the other around 14% from memory.. The main thing is they both rise and fall as the pedal is used.. It would be nice to be able to view live data on a scan tool of the tpp sensor outputs when the fault occurred.. Can't think of much else atm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
You could do with a fully functioning model, to compare specs with really.
Could anyone do that with a 2.2? It might be the throttle needs replacing due to issues with it mentioned by Andy just above. (Who has more knowledge of it than me). Perhaps a take off part might be a possibility? TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
kevin-h Member Since: 24 Mar 2020 Location: Huddersfield Posts: 27 ![]() ![]() ![]() |
Thanks guys,
Yes, ideally i’d like to get some live values from a known good vehicle to compare but I don’t have anyone I know that I can ask. |
Try asking Gary @ Alive or Pete @ Bell Auto they know their stuff when it comes to these things.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3483 ![]() ![]() ![]() |
What software are you using? Did you do the test with engine running, or just the ignition on? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
If you want the values that a scan tool or say the torque app will generate in terms of a percentage readout I've had a look at my 2.2l today.. I was only quoting from memory above But the readouts for tpp sensors D and E Are.. With acc pedal not in use the respective readings are 31.7%… And 7.8%.. If you then fully depress the throttle they become 100% and 37.25% at fully depressed pedal.. That's from a truck that is running with no issues so that's what you should expect to see.. Just download torque.. Even the pro version is only a few pounds and very handy 👍 If you need scope voltage values off the signal wires I should be able to do that at some point in the next few days but I think the above should do.. The problem would be it the fault was an intermittent one and then you are either needing on road monitoring or just substitution of the unit to see if that solves it.. 👍 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2149 ![]() ![]() |
An eddy quick thing to do.
Disconnect the wiring connector, give both set of contacts a good spray with electrical contact cleaner, give 10 plus mins to ensure evaporation. Then reconnect connector and see if that improves things. |
Thanks Dinnu, I did this with the engine running but a local garage did the same with the ignition off and observed the same values. |
I was using a Gap Diagnostics IID tool |
Thank you Andy, I will fully depress and see what values I get. |
Sorry, do not have that tool, otherwise would have gladly run the same tests. I have a cheapo ELM327 and Car Scanner software which I can do some tests with. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I have got readings for pedal not depressed and pedal fully depressed;
Pedal not depressed ![]() Click image to enlarge Pedal fully depressed ![]() Click image to enlarge Do these values correspond with you andy63? |
Hi kev... That appears to be half the story.. Its showing tpp sensor circuit D.. Starting at 30% and going to 100%..
Does your reader not give tpp circuit E for the second potentiometer... The mid two readings appear to show two sensors reacting in the correct manner.. The other readings appear to show the electronic throttle in more or less a wide open position which would be correct.. |
Thank you Andy
I don’t have a circuit E to choose with my tool. I do have some different pedal stats though which I’ve included here; Pedal not depressed ![]() Click image to enlarge Pedal fully depressed ![]() Click image to enlarge Are these more helpful? |
