Home > Technical > ATB (torsen) front and rear install
Page 23 of 24 <123 ... 222324>
geobloke
Naks wrote:
Gents, I have the option to buy a 2nd hand ATB with 10,000km at half the price of a new one.
Worth it? What could be wrong in there that a visual inspection won't reveal?
Given your location as long as the unit is in good nick then I would jump on that. Thumbs Up
Post #1031332 12th Apr 2024 10:10am
Naks
^ And so I did!
Got it fitted, and straight away noticed the following:
- the steering is a lot heavier
- there is a lot more understeer now
- the steering doesn't return to centre as quickly
Oh well, gone are the days of slinging it around the many traffic circles in town then Rolling with laughter --
Post #1032898 26th Apr 2024 8:53am
geobloke
Never fear Naks it does improve a lot Thumbs Up Give it time and you'll find that the ATB will loosen up a bit and the understeer will reduce and the steering lighten. Or you will grow bigger muscles Rolling Eyes
Post #1032913 26th Apr 2024 9:39am
excossack
I can still get my landy and a trailer through tyre chicanes on race circuits at the same speed I could before getting a front ATB fitted.
What under steer Smile all is well in that area 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1032917 26th Apr 2024 10:16am
Naks
At full lock, e.g., turning in & out of a parking bay, there's some grabbing - is that normal? Any way to dial it back a touch? --
Post #1032932 26th Apr 2024 12:32pm
Naks
^ turns out that the workshop forgot to refit the turn stoppers Evil or Very Mad --
Post #1033210 29th Apr 2024 8:24am
geobloke
As in the steering stops on the swivel housings? Shocked
Post #1033431 30th Apr 2024 7:56pm
Naks
^ yep, those very same ones. no wonder the tyres were grabbing at full lock.
took it back, and they fitted them on the spot, and adjusted the handbrake as well, it was clanking at low speeds. --
Post #1033475 1st May 2024 8:19am
Naks
Did a trail this weekend, it was raining quite a bit, so slippery gravel/rocks.
Not sure the front ATB made a big difference, TBH... --
Post #1033926 6th May 2024 8:19am
Naks
While investigating a clunk in the rear diff when taking off from standstill, this is what we found:
https://www.reddit.com/r/LandRoverDefender...r_6_years/
there was also no play at all on the crown when cold, so it was eating the rear side shafts. --
Post #1036796 7th Jun 2024 8:07pm
Unfortunately whatever is in your link requires the installation of an "app" (which I have no intention of doing) and is not viewable without.
Post #1036802 7th Jun 2024 8:53pm
Naks
odd, it's just a reddit link Rolling Eyes --
Post #1036803 7th Jun 2024 9:00pm
MK
Any clues why this happened?
It can be fixed I reckon
https://new.reddit.com/r/LandRoverDefender...r_6_years/
 Puma 110" SW
Post #1036804 7th Jun 2024 9:02pm
Naks
dunno, I started experiencing a clunk when driving from standstill, so this is what led us here.
This Ashcroft ATB was installed in August 2017, and has done about 24,000km. So I guess the bearings eventually got loose enough to start causing the issue? --
Post #1036806 7th Jun 2024 9:05pm
Castillo
Finland
Hello,
I need help.
Which cv-joint (abs) is good enough to replace the original one in defender td5. I am restoring the front axle and installing ashcroft ATB at the same time. The front sprocket bolt 1/10 broke (driven 280,000km) and broke some the insides. I think that the original cv-joint is already a little worn out, even though the pores of the camshafts are still good. What is britparts cv-joint quality? or Febi, Triscan, FAG
Thanks for the advice! defender 110 td5 2006
Post #1042330 9th Aug 2024 3:53pm
