![]() | Home > General & Technical (L663) > Speed limit warning - permanently turn off? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2728 ![]() ![]() |
It’s a regulatory requirement for new vehicles I believe. Whether the regulations say it can’t be disabled or not I’m not sure.
It can be disabled permanently in the vehicle software with the right kit, there are companies offering this service. I’ve not seen anyone figure out how to do it DIY with an IIDTool yet sadly. |
Mrburt Member Since: 04 Jan 2023 Location: Shropshire Posts: 37 ![]() ![]() |
You can navigate to your custom setting by just pressing the DAS button twice on the left hand side of the steering wheel controls. Yes you have to do it every time on start up but it’s just two quick presses and you are good to go. To set your custom settings press the same DAS button for one long press and then set your preferences on the main screen under custom. Sadly as other have said it is now mandatory for all new 2024 cars, however there are companies that will ‘code’ it out if required. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3460 ![]() ![]() |
I’m still getting used to pressing the button each time. 24MY 90 D250 HSE, Tasman Blue
dizeeduckie Member Since: 10 Sep 2021 Location: London Posts: 62 ![]() ![]() |
Could you link to any of them, please? |
What does DAS mean? |
Plenty on this list: https://www.google.com/search?q=defender+l...ce+disable |
That just links to a google search of forums discussing the problem.
You said there are companies offering the service of disabling the system. I can't find any companies offering this service so I wonder if you could please point me to the companies you know offer this service? Thanks. |
Oswiperus Member Since: 12 Aug 2020 Location: Chelmsford Posts: 52 ![]() ![]() |
If you scroll down just a little there are 2 or three companies as Retroanaconda has pointed out. 110 D250 S Hardtop Tasman Blue
Apologies - you're correct.
Thanks. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
How does the vehicle know the speed limit for any road. ?
Is it by Road Sign Recognition then it's the camera that is picking up 'stray' signs. I get a reading of 10mph each time I pass a left hand turn into a small industrial estate, although I haven't actually turned left ! Also the it will not correct the 'true' limit until it reads another sign. I have fitted a separate display that tells my actual speed by monitoring multiple satellites. |
A combination of the cameras picking up signs and the sat nav database information.
neither of the above are admissible in court, sadly.
What has court got to do with speed sign detection?
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 63 ![]() ![]() ![]() |
Here is a link to Hunters Prestige that offer the activation of it remembering the last user setting.
https://huntersprestige.com/collections/de...ry-disable Still waiting for someone to figure out how to change it with GAP tool. 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
