Home > Maintenance & Modifications > Half-Door 110 Puma alarm activation issues. |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 461 |
I have a similar problem. In my case a Puma 90. Just had a respray, so lots of panel and electrical disturbance but now when I press the fob to lock the car it locks and the horn alarm toots twice. The indicators do not flash. It unlocks from the fob ok.
I did notice a sleeved white wire hanging down by the drivers door hinge that has nowhere to go, perhaps it is the culprit but where should it go? Wiring diagram shows several white wires. The white wire could also be nothing to do with the problem. Any help gratefully appreciated. Thanks. 2.2 90 XS 88" Series One Old Norton Minerva |
10th Apr 2024 2:38pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2302 |
You could trick the ECU into thinking the central locking actuators are still there by adding a resistor between the two pins in the (now unplugged) connector. Not sure what ohmage it would need to be, you could measure the resistance across the removed actuators? > 110 XS Double Cab
10th Apr 2024 2:51pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Disconnect the door switches and try Instagram @defender_ventures
Empire Tuning - Agent |
10th Apr 2024 6:01pm |
