Home > Td5 > OE wiring
110Matty
OE wiring
Hello everyone,
Anyone know where i can get hold of some genuine coloured wiring for my TD5 90 (2004)? I'm doing various additions, alterations, extensions and where possible would like to use the OE wiring spec, if nothing else to help identification in future. I'd only need a few metres of each, but can't seem to find any online, or anyone else asking for it on the forums searches.
Cheers.
Post #1031146 10th Apr 2024 8:49am
130dreamer
I have a TD5 main wiring loom which has already been partially butchered.
If you let me know which colours/size you need and the lengths required I can send you them for the cost of postage.
Can't promise I have everything you need but maybe of some help?
Post #1031147 10th Apr 2024 8:58am
Martin
Site Admin
I've found ALM Solutions have the widest range of sizes and colours, but they don't do everything as LR used some strange combinations.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1031151 10th Apr 2024 9:18am
110Matty
That's a very kind offer and much appreciated, even if you don't have what i need. Here goes (i hope i have read the wiring diagrams correctly):
Clock - Red / Orange (R/O) illumination (common to most / all of the gauges and switches i think)
Clock - Purple / Brown (P/N)
Rev Counter - White / Slate (from ECU pin 19 - is present in the connector behind the binnacle / gauge panel) and R/O illumination
Heated Seats (appreciate this might be a long shot) - Blue / Slate (U/S), Light Green / White (Lg/W) and of course R/O for illumination
I already have standard wiring in red and black and a few random others.
I am a newbie, so i don't have much to offer in return yet, but if you are after something random, ask away - odd dash screws, switch blanks, aftermarket electric window switches, spare washer pump, rear / safari door lock body (non central locking and barrel removed) kind of thing. Perhaps i should put them on the for sale section at little to no cost Embarassed
Post #1031155 10th Apr 2024 9:39am
110Matty
Thanks Martin, I'll have a look - could be good to know for now or in the future.
p.s. you kindly replied to me about rear wash wiring and i thought i'd found the plug for it (despite not having rear wash / wipe originally) - you identified it as part of the alarm sounder, did you have any thoughts why my alarm still sounds (i think normally) even though that cable was not connected to anything? My alarm is a single tone, continuous horn - is that normal? (Apologies for adding this here, perhaps would have been better on the original post, but i didn't want to hassle you, but now i have you !!! Rolling Eyes
Post #1031156 10th Apr 2024 9:45am
PaulMc
110Matty wrote:
... Here goes (i hope i have read the wiring diagrams correctly):
I can supply -
in 0.5mm² -
Red/Orange
Purple/Brown
I can 'stripe' White with Grey
in 1.0mm² -
Blue/Grey (LH seat)
Blue/Pink (RH seat)
White/Green (Light Green/White is the colour used on Discovery-2)
Red/Orange
All by the metre.
. Paul.
Post #1031181 10th Apr 2024 2:58pm
110Matty
Many thanks Paul, assuming i can't get what i need from @130dreamer, could you PM the prices, or let me know here?
Interestingly though (or not maybe?), the Haynes manual and the Land Rover electrical manual show different things - unless I'm a real numpty, both diagrams / photos below are for TD5 post 2002 (mine is 2004). Both show Lg/W and the LR manual for RH as Blue/Pink and LH as Blue/Slate but the Haynes (where i took my initial info from, shows both as Blue/Slate??
ual shows RH seat
Post #1031184 10th Apr 2024 3:41pm
PaulMc
"The Haynes book of lies" Laughing
110Matty wrote:
... Both show Lg/W
You're correct Embarassed - the 'factory' feed is in LG/W
I said W/G - as that's the colour I use in my heated seat wiring kits, which take the wiring for the heated seat switches (W/G, R/O, B) from the hazard warning light switch or cigarette lighter circuits, depending on vehicle age.
My kit uses relays to switch the seats, so the dash switches are only switching relay coils.
BTW - I have Light Green/White - but, only in 1.0mm²
. Paul.
Post #1031186 10th Apr 2024 3:58pm
Martin
Site Admin
LGW is correct
https://www.lrworkshop.com/wiring-diagram/...ated-seats
Error in the HBOL to say both are US  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1031188 10th Apr 2024 4:08pm
110Matty
I thought that might come out (Haynes), but ref your point about Lg/W being relevant to Disco 2, the LR manual also shows it - what do you think it should be if not Lg/W ? I might just use red as i take it that's the switched live (Pin 1 on both connectors) ?Cheers.
Post #1031189 10th Apr 2024 4:08pm
110Matty
110Matty wrote:
... Both show Lg/W
I’m using relays too. I have Mazda bucket seats (fitted by PO, very comfortable to be fair) and not 100% sure of current draw, suspect it’s between 5 and 10 amps each, but I’m guessing really. I know Land Rover went direct from switch but I’m going relays.
Post #1031212 10th Apr 2024 7:51pm
110Matty
Pm sent for purchase, thanks.
Post #1031581 14th Apr 2024 11:02pm
