![]() | Home > Td5 > Loose pipe? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1644 ![]() ![]() |
fuel tank breather. clips in on the side of the rear tub. prone to cracking with old age and leaking fuel.
that's the old version as new one runs along side the filler pipe on a t piece now |
Lunar Landy Member Since: 02 Jun 2023 Location: Northamptonshire Posts: 39 ![]() ![]() ![]() |
Thanks for that, I had a look around the wheel arch but couldn’t find where it’s fitted, should it be vertical or ok as it is? There is a similar diameter pipe near the fuel filling pipe.
google fuel vent pipe defender
it'll show you both types and where they go |
