Home > Td5 > Loose pipe?
Lunar Landy
United Kingdom 2003 Defender 90 2.5 TD HT Bonatti Grey
Loose pipe?
Hi All,
Can anyone identify this pipe with a formed bend, approximately 5 mm dia. located in the rear left wheel arch, and where it should be fitted?
Thanks
Post #1030971 8th Apr 2024 4:09pm
Mdm
fuel tank breather. clips in on the side of the rear tub. prone to cracking with old age and leaking fuel.
that's the old version as new one runs along side the filler pipe on a t piece now
Post #1030972 8th Apr 2024 4:14pm
Lunar Landy
Thanks for that, I had a look around the wheel arch but couldn’t find where it’s fitted, should it be vertical or ok as it is? There is a similar diameter pipe near the fuel filling pipe.
Post #1030974 8th Apr 2024 4:19pm
Mdm
google fuel vent pipe defender
it'll show you both types and where they go
Post #1030992 8th Apr 2024 8:02pm
Lunar Landy
Very Happy Thanks
Post #1031041 9th Apr 2024 7:34am
